Boe-Bot Still With CMU1
Hello,
I recently received the CMUcam1 for my Boe-Bot.· I believe I installed it according to the directions:· camera pins inserted into appmod connector, other 2 pins connected to Vdd, lens cap off.·
However, the bot will never move when its supposed to "track a color" or "move and avoid".· I used the 8 demo functions to calibrate lighting and save sample color before going to the tracking, but still no movement.· I tried replacing the batteries, and testing the servos by loading a·movement program.· The LED's appear to light up according to the tracking program, just no movement of the bot itself.
Any ideas?
thanks,
Any ideas?
thanks,
D Faust
Faust, is is necessary to do what you said?· ·As I mentioned, I loaded another program to make the servos go, and they did.
Steve, it is the BoeBot cam.· It's not a stupid question, I apologize if I was not clear.
Post Edited (LogJam00) : 6/10/2007 4:46:53 PM GMT
D Faust
Check back in and let us know how you get on... might also be useful to post some actual code and the results you get from the various debug statements
Regards
Duncan
I have not written any of my own code for this yet, as I was getting used to the cam.· The CMUcam comes with a program which includes 8 demo modes, using this:
'{$STAMP BS2}
'{$PBASIC 2.5}
' CMUcam1 BoeBot AppMod 1.2 Demo Program
' Copyright 2006, Seattle Robotics
' Basic Stamp 2
' CMUcam1 jumpered for 9600 Baud
' RA Nucci 07/13/2006
' Setup pins for buttons
INPUT 6
INPUT 8
HIGH 6
HIGH 8
RcvData VAR Byte(10) ' Array
SaveColorData VAR Byte(6) ' Array
Result VAR Word
N VAR Byte ' General purpose counter variable
LostTrack VAR Nib
Switch VAR Nib
Debounce VAR Nib
Function VAR Nib
Main:
' Pause for CMUcam1 startup
· FOR N = 2 TO 5 ' Flash all LED's during pause
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]255]
··· PAUSE 400
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0]
··· PAUSE 400
· NEXT
· FREQOUT 10, 400, 2500 ' Beep to indicate ready
ProgTop:
· ' Select function from push buttons
· GOSUB GetButton
· Debounce=Switch
· GOSUB GetButton
· ' Get button press twice and compare if not the same repeat
· IF Debounce <> Switch THEN ProgTop
· IF Switch = 2 THEN ' If Go/Stop button pushed then beep
··· FREQOUT 10, 400, 2500 ' beep
· ENDIF
BRANCH Switch, [noparse][[/noparse]ProgTop,Buttonselect,Execute]
Buttonselect:
· Function = Function + 1
· IF Function > 9 THEN
··· Function = 1
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]1]
· ENDIF
· PAUSE 300
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]DCD(Function-1)]
GOTO ProgTop
Execute:
· BRANCH Function, [noparse][[/noparse]ProgTop,Calibrate,SaveColor,TrackColor,Avoid,Adapt,FollowLine,Point,Color]
GOTO ProgTop
GetButton:
· Switch=0
· IF IN6 = 0 THEN
··· Switch = 1 ' Select button pressed
··· RETURN
· ENDIF
· IF IN8 = 0 THEN
··· Switch = 2 ' GO/Stop button pressed
··· RETURN
· ENDIF
· IF IN8 = 0 AND IN6 = 0 THEN
··· Switch = 3 ' Both buttons pressed at the same time
· ENDIF
RETURN
' Track the color previously saved in EEPROM
TrackColor:
· GOSUB ConfigureCMUcam
· ' Read EEPROM into SaveColorData array
· READ 0, SaveColorData(0)
· READ 1, SaveColorData(1)
· READ 2, SaveColorData(2)
· READ 3, SaveColorData(3)
· READ 4, SaveColorData(4)
· READ 5, SaveColorData(5)
· ' Set Track Color values from EEPROM
· SEROUT 7,84,[noparse][[/noparse]"TC"]
· SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(0)]
· SEROUT 7,84,[noparse][[/noparse]" "]
· SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(1)]
· SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(2)]
· SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(3)]
· SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(4)]
· SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(5),CR]
· PAUSE 200
TopTrack:
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' All LED's off
· GOSUB GetButton· ' Check for stop button press
· IF Switch = 2 THEN' Switch 2 is stop button
· ' Two beeps for Stop
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]DCD (Function-1)]
··· PAUSE 200
··· PAUSE 200
··· ' Reset the green tracking LED
··· SEROUT 7, 84, [noparse][[/noparse]"L1 0",CR] ' Green LED off
··· PAUSE 100
··· SEROUT 7, 84, [noparse][[/noparse]"L1 2",CR] ' Green LED auto mode
··· PAUSE 100
··· GOTO ProgTop
· ENDIF
· ' Send command - Track color (with no arguments) -
· ' will track last color grabbed by TW command
· SEROUT 7, 84, [noparse][[/noparse]"TC",CR]
· SERIN 9, 84, [noparse][[/noparse]STR RcvData\10]
· PAUSE 100
· ' 45 is aprox H center, 70 is aprox V center
' Track and follow logic
IF Function = 3 THEN
· IF RCVData(2) > 65 AND RcvData(9) > 25 THEN RotateLeft
· IF RCVData(2) < 25 AND RcvData(9) > 25 THEN RotateRight
· IF RCVData(7) > 120 AND RcvData(9) > 25 THEN Bwd
· IF RCVData(7) < 60· AND RcvData(9) > 25 THEN Fwd
ENDIF
' Move and avoid logic
IF Function = 4 THEN
· IF RCVData(3) > 50 AND RcvData(9) > 20 THEN Fwd
· IF RCVData(3) < 50 THEN BackUp
· IF RcvData(9) <= 20 THEN BackUp
ENDIF
' Adaptive tracking logic
IF Function = 5 THEN
· IF RCVData(7) < 60 AND RcvData(9) > 25 THEN Fwd
· IF LostTrack > 6 THEN TW
· LostTrack = LostTrack + 1
· IF RcvData(9) > 25 THEN LostTrack = 0
ENDIF
' Line Following logic
IF Function = 6 THEN
· IF RCVData(2) > 50 AND RcvData(9) > 5 THEN TurnLeft ' 45
· IF RCVData(2) < 40 AND RcvData(9) > 5 THEN TurnRight ' 45
· IF RCVData(2) >= 40 AND RCVData(2) =< 50 AND RcvData(9) > 5 THEN Fwd
ENDIF
' Finger point logic
IF Function = 7 THEN
· IF RCVData(2) > 60 AND RcvData(9) > 25 THEN RotateRight ' Centroid X
· IF RCVData(2) < 30 AND RcvData(9) > 25 THEN RotateLeft ' Centroid X
· IF RCVData(3) > 30 AND RcvData(9) > 15 THEN Bwd ' Centroid Y
ENDIF
' Color logic
IF Function = 8 THEN
· SEROUT 7, 84, [noparse][[/noparse]"TC 30 240 16 30 16 30",CR] ' Red
· IF RcvData(9) > 20 THEN
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]195] ' All Red LED's on
··· PAUSE 500
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' All LED's off
· ENDIF
· SEROUT 7, 84, [noparse][[/noparse]"TC 16 40 30 240 90 170",CR] ' Green
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]24] ' All Green LED's on
··· PAUSE 500
· ENDIF
· SEROUT 7, 84, [noparse][[/noparse]"TC 200 240 200 240 16 50",CR] ' Yellow
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]36] ' All Yellow LED's on
··· PAUSE 500
· ENDIF
ENDIF
· ' Flash LED's to show bottom of tracking loop
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]129] ' 100000001
GOTO TopTrack
' Calibrate CMUcam1 for lighting conditions
Calibrate:
· ' Reset CMUcam1
· SEROUT 7, 84, [noparse][[/noparse]"RS",CR]
· PAUSE 200
· ' Turn on auto adjust
· SEROUT 7, 84, [noparse][[/noparse]"CR 18 44",CR]
· PAUSE 100
· ' Delay loop for CMUcam1 to auto adjust to lighting conditions
· FOR N = 2 TO 255
··· PAUSE 100
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]DCD (N)]
··· GOSUB GetButton ' Check for stop button pressed
··· IF Switch = 2 THEN EXIT ' Switch 2 is stop button
· NEXT
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' 000000000
· ' Turn off auto adjust
· SEROUT 7, 84, [noparse][[/noparse]"CR 18 44 19 32",CR]
· PAUSE 100
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]1] ' 100000000
· PAUSE 300
GOTO ProgTop
SaveColor:
' sample and save color
· SEROUT 7,84,[noparse][[/noparse]"PM 1",CR]
· PAUSE 100
· ' Set a small window in center
· SEROUT 7,84,[noparse][[/noparse]"SW 30 54 50 90",CR]
· PAUSE 100
· ' Set raw mode 3
· SEROUT 7,84,[noparse][[/noparse]"RM 3",CR]
· PAUSE 100
· 'set minimun and maximun values
· SaveColorData(0)=16
· SaveColorData(1)=240
· SaveColorData(2)=16
· SaveColorData(3)=240
· SaveColorData(4)=16
· SaveColorData(5)=240
· ' Get Mean
· SEROUT 7,84,[noparse][[/noparse]"GM",CR]
· SERIN 9,84, [noparse][[/noparse]STR rcvdata\8]
· PAUSE 200
· IF rcvdata(2)<=46 THEN gm1
··· SaveColorData(0)=(rcvdata(2)-30)
· gm1:
· IF rcvdata(3)<=46 THEN gm2
··· SaveColorData(2)=(rcvdata(3)-30)
· gm2:
· IF rcvdata(4)<=46 THEN gm3
··· saveColorData(4)=(rcvdata(4)-30)
· gm3:
· IF rcvdata(2)>210 THEN gm4
··· saveColorData(1)=(rcvdata(2)+30)
· gm4:
· IF rcvdata(3)>240 THEN gm5
··· saveColorData(3)=(rcvdata(3)+30)
· gm5:
· IF rcvdata(4)>240 THEN gm6
··· saveColorData(5)=(rcvdata(4)+30)
· gm6:
· ' Set raw mode to 0
· SEROUT 7,84,[noparse][[/noparse]"RM 0",CR]
· PAUSE 100
· ' Return window to full size
· SEROUT 7,84,[noparse][[/noparse]"SW",CR]
· ' Write color tracking range values to end of EEPROM
· WRITE 0,saveColorData(0)
· WRITE 1,saveColorData(1)
· WRITE 2,saveColorData(2)
· WRITE 3,saveColorData(3)
· WRITE 4,saveColorData(4)
· WRITE 5,saveColorData(5)
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]2]
· ' Two beeps
· PAUSE 400
· PAUSE 400
GOTO ProgTop
Avoid:
· SEROUT 7,84,[noparse][[/noparse]"TW",CR]
· PAUSE 1000 ' Wait 1 second for TW
GOTO TopTrack
Adapt:
TW:
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]255] ' All LED's on
· FREQOUT 10, 150, 2500 ' Beep
· PAUSE 100
· SEROUT 7,84,[noparse][[/noparse]"TW",CR] ' Send Track Window command
· PAUSE 1000 ' Wait 1 second for TW to complete
· LostTrack = 0 ' Reset LostTrack counter
GOTO TopTrack
FollowLine:
· SEROUT 7,84,[noparse][[/noparse]"TC 16 50 16 50 16 50",CR]' Black line color
· PAUSE 100
GOTO Toptrack
Point:
· SEROUT 7,84,[noparse][[/noparse]"TC 200 240 180 240 50 100",CR] ' Skin color
· PAUSE 100
GOTO Toptrack
Color:
GOTO Toptrack
ConfigureCMUcam:
· SEROUT 7,84,[noparse][[/noparse]"PM 1",CR]' Poll Mode
· PAUSE 100
· SEROUT 7,84,[noparse][[/noparse]"RM 3",CR]' Raw Mode
· PAUSE 100
· SEROUT 7,84,[noparse][[/noparse]"CR 32 8",CR]' White Balance smart mode
· PAUSE 100
RETURN
BackUp:
· ' backup
· FOR n = 1 TO 15
··· PULSOUT 14,1000 ' **
··· PULSOUT 15,500 ' **
··· PAUSE 15
· NEXT
· PAUSE 200
· ' rotate about 90 degrees
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]32]
· FOR n = 1 TO 100
··· PULSOUT 15,1000 ' **
· NEXT
GOTO TopTrack
RotateLeft:
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]4]
· FOR n = 1 TO 10
··· PULSOUT 14,500 ' **
· NEXT
GOTO TopTrack
RotateRight:
· FOR n = 1 TO 10
· NEXT
GOTO TopTrack
TurnLeft:
· FOR n = 1 TO 40
··· PULSOUT 15,750 ' **
· NEXT
GOTO TopTrack
TurnRight:
· FOR n = 1 TO 40
··· PULSOUT 14,750 ' **
· NEXT
GOTO TopTrack
Bwd:
· FOR n = 1 TO 10
··· PAUSE 15
· NEXT
GOTO TopTrack
Fwd:
· FOR n = 1 TO 10
··· PAUSE 15
· NEXT
GOTO TopTrack
All 8 demos are in this above code, and you choose which mode by pressing a button on the CMUcam board.· A corresponding LED lights to show which of the 8 modes you have chosen.·
Full documentation is here:· http://www.parallax.com/dl/docs/prod/robo/cmucamman.pdf
First, I chose Mode 1 to calibrate the cam to my lighting, then Mode 2 to let the cam know what color I wanted to track, then on to Mode 3 to start the tracking.· As the object of the color used in Mode 2 is moved, then Mode 3 uses a series of LEDs to show which the direction the bot will move, and the bot moves in that direction to track the object.· The LEDs appear to light correctly, but the bot will not move.
I am open to suggestions as to what DEBUG statements you would recommend in order for me to test this.·
Thanks for the replies!
