Helpme for bs2 and PCF8563 — Parallax Forums
beppexscienzabeppexscienza Posts: 3
edited 2007-06-08 06:47 in BASIC Stamp
hi,
send me code for interface bs2 to RTC PCF8563 and LCD02
PIN BS2: P15 LCD, P5 RTCSDA, P6 RTCSCL
thank's
  • beppexscienzabeppexscienza Posts: 3
    edited 2007-06-07 08:18
  • Skywalker49Skywalker49 Posts: 172
    edited 2007-06-07 21:40
    Hi Bep.....scienza,
    here is an example to couple the LCD02 to a Basic Stamp BS2p.
    The BS2p supports the I2CIN & I2COUT commands, the other
    BS2 models don't in which case you have to develop some software.
    I never did that but here is the place where you can find it all explained in detail.
    http://www.parallax.com/dl/docs/cols/nv/vol5/col/nv115.pdf
    The other part, coupling the PCF8563 Real Time Clock via the I2C protocol (SDA to input 5 and SCL to input 6),
    the same story .. I2C and the above link should help you.
    good luck,
    Ed
    Post Edited (Skywalker49) : 6/7/2007 10:19:58 PM GMT
    Translate with program
    thanks of the answer
    I knew like program the device lcd02 in serial mode for bs2.
    My problem is like programming the RTC and visualizing hour, date on display
