No Continuous $GP... strings from GPS receiver module
Hi, I have a Paralllax GPS module. It sends out a beep every one second and it locks on to the satellites, but does not send any &G... strings unless I wrap my fingers around the module. I am using it in the raw mode and have it connected to a Tiny Trak III and then a VX-2R HT so I can monitor what it sends.
Elliott·
Post Edited (ElliottE) : 6/6/2007 7:17:22 PM GMT
Elliott·
- Stephen
Elliott
Allow TTL Serial
If this option is enabled, TinyTrak3 will check the serial input level at power-up to determine if it is connected to a RS-232
or TTL level GPS. If not using a TTL level GPS, this option should be left disabled. If enabled, and TinyTrak3 detects a
TTL GPS, it will flash the yellow and green 3 additional times at power up. This will invert the polarity of the GPS input
signals.
Also make sure that you have a common ground between the two (Parallax GPS receiver & TT3)
BTY: You might want to go back and edit your original post and add a subject line
Post Edited (Mike Cook) : 6/6/2007 2:26:33 AM GMT
Elliott
