Humidity effects on Prop?
Has anyone else noticed a problem with USB communications with the Prop or the Prop Dev Kit in cases of high humidity?
I'm trying to isolate a problem I've had sporadically: one evening, about a month ago, during a rainstorm, my prop started requiring multiple attempts to download a program, either to RAM or EEPROM. About 1/3 of attempts would work, otherwise, I would get most of the way, and then during the Verifying RAM process, I would get a "Propeller chip lost on COM7" message.
I wondered at the time if it might be due to the humidity/lightning, but as the problem stopped the next day, I didn't think much about it. In the meantime, once on board, the programs run fine.
This happened again last night, except that with the exception of a very small demo program, I was entirely unable to load anything onto the prop. I checked, and the humidity here in Boston was listed as 100%. Now today, I am able to load a very short LED blinking program, but no long programs (like something including BS2_Functions object. Humidity is currently 73%.
Am I confusing correlation with causation? Could I even consider it correlation? Has anyone else encountered this?
Alex
Alex
Paul Baker
I just tried the same on a backup prop kit I just opened. Same problem: short program took 4 downloads, long program won't work at all. I'm using a different power supply, but same computer.
Any thoughts about what the problem could be?
Alex
Paul Baker
I'm currently set up with my backup prop kit, *no* external connections, just the power supply and USB.
When I go to download anything to RAM, the first time it says, "no propeller chip found", and reboots chip. Then the next time I usually hit F7 first, and it finds the chip, then I hit F10, and it locates the chip, begins download, etc etc until during verification, it says the chip is lost.
Post Edited (squidx) : 6/5/2007 3:47:00 PM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Thanks again,
Alex
Paul Baker
