IGBT's... — Parallax Forums
IGBT's...
ChrisPChrisP Posts: 136
edited 2007-06-07 17:33 in General Discussion
Graduating from FET's to IGBT's or trying to for higher power applications..
First logic would seem to dictate that since it has a gate instead of base, partially on would be a bad thing... Is this true of IGBT's?
Do these things share current nearly as well as fets do, or should I not look at parallel sets and just go with monsters for whatever I'm working on?
Testing an IGBT, if it shares some of the characteristics of a FET I guess a gain test is out of the question?
Dual package half bridge configuration, my guess so far is that I should get a somewhat consistant resistance reading with the proper polarities back to the center of the half bridge. Is that far off?
Been reading some data sheets, there doesnt seem to be a whole lot on Google thats plain and simple basic high power info so I'm hoping for forum help since I've learned so much here already.
Thanks!
Chris
  • metron9metron9 Posts: 1,100
    edited 2007-06-05 13:02
    It seems that IGBT's have an isolated FET gate so they are driven with voltage and use almost zero current. (typically 100nA or less, one billionth of an amp)
    http://en.wikipedia.org/wiki/IGBT
    Think Inside the box first and if that doesn't work..
    Re-arrange what's inside the box then...
    Think outside the BOX!
  • stamptrolstamptrol Posts: 1,731
    edited 2007-06-05 14:06
    Most IGBT's are used in either high voltage or high current work. My work with them is in 600 VAC frequency drives.
    As metron has pointed out, it is a packaged unit consisting of a MOSFET front end for ease of control and a BJT backend for brute strength and current carrying capacity.
    What is your application in terms of voltage and current?
    Cheers,
    Tom Sisk
    http://www.siskconsult.com
  • ChrisPChrisP Posts: 136
    edited 2007-06-05 14:25
    I'm looking at them for several reasons right now.
    First is that I'm working with them in 300-600 volt applications but really only in a repair scenario and thats why I'm looking at different ways to check the condition. Shorted is obvious, but there has to be a better test to tell actual condition, not just that it works or doesnt.
    Second because of the same repair scenario its not unusual to run across IGBT blocks with 1 or 2 half bridge sections still functional, so it would be nice to look at these units for 12-96 volt applications. High current H bridge tinkering etc.
    Lastly, its a continuing education thing. In the low voltage arena 10-24 volts I've been using the IRLZ44NS's quite happily, in singles and parallel operation. Since I'm now working with IGBT's on a limited basis at work I'd like to learn more.
    Specificaly just wondering about the simple things to watch out for, quirks due to the hyrbid fet/transistor combination.
    The picture I'm getting so far is that an IGBT is a very high voltage or high power transistor package with a fet drive and internal bias to simplify use. Does this cause strange things to show up in general if they are used for a much lower voltage than their rating, or do they work more like a fet than a transistor with a high fixed current gain?
    An example part would be a CM100TF-12H as a single leg, or a MG100J6ES50 as a six pack. Both 600 Volt pieces, one nice thing if I can use the partials in tinkering. Back EMF shouldnt be much of an issue at 24 Volts.... lol
    edited 2007-06-05 16:41
    For tests of a high voltage unit, set up a circuit of say 24 volts with a resistor of 2 ohms or so so you can draw a reasonable amount of current. Use a 10K resistor to pull the gate to ground to hold the unit off. Apply +24 volts through a 1K resistor to the gate. The main terminals should conduct. Remove the gate voltage and the main circuit should should go open.
    The usual transistor failure in a drive is dead short or completely open so the above test will confirm that.
    These are good units to play with and do sometimes fail with one part still good. Use them on the bench to play with, but avoid the urge to try to reuse them in the original application!
    Cheers,
    Tom Sisk
    edited 2007-06-05 16:49
    Reuse in the original application is out of the question. Reuse in home brew Hbridges and such to tinker with is another story entirely. From what you just told me I pretty much treat it just like an N channel FET then. Thats easy enough. Do they parallel as easy as FET's or should I be careful of that?
    The standard test circuit I was aware of, I'm looking more for a "Where in its life cycle is it?" kind of test. Working but worn type thing...
    edited 2007-06-05 16:56
    Chris,
    Parallelling requires the same consideration as paralleling plain BJT's. Usually requires some playing around with emitter resistance and making sure no transistor can heat up more than the others. Just check any text on transistors.
    Life cycle; maybe with lots of time and a curve tracer you might be able to make a prediction, but these things a re pretty much on/off, work or don't work things.
    Tom Sisk
  • bennettdanbennettdan Posts: 614
    edited 2007-06-05 20:31
    ChrisP,
    I have parralleled IGBT and they load share like a Fet one will get a little hot then the other will conduct more untill the hot one cools enough to conduct again. I have found that if you drive the IGBT over 15khz they are not as good as using a Mosfet but the IGBT will handle very high voltages and the internal diode will handle the high voltages also but an external is recomended also. Most data sheets say that a IGBT will be fully saturated with a 15vdc signal and I have used 15vdc in all of my circuits. The Powerex company http://www.pwrx.com/ has loads of info on their IGBT moduals they have some that will handle hundreds of amps even up to 2k amps. They use +15vdc to the gate to saturate the IGBT and then use -15vdc to turn it off fully but I have found that 0vdc is good enough to stop the saturation.
  • Rob7Rob7 Posts: 275
    edited 2007-06-05 20:39
    Did you check out the high power leader in IGBT's. WWW.IRF.COM
    You should be able to find just what you are looking for.
    Most of the IGBT's are manufactured here in Temecula, Ca.
    Rob7
    edited 2007-06-06 01:32
    www.irf.com/technical-info/whitepaper/choosewisely.pdf
    - Stephen
    Thanks everyone, like always this forum is a fantastic place to gather information.
