Having problems getting the LTC1298 to read more accurately.
pimp200277
My problems is I can't seem to get my ADC - LTC1298 (12-bit analog to digital converter) to read my pH sensor accurately enough.
My pH sensor output for what I am measuring·is suppose to be ·about 2.25volts.
so after converting the analog reading to voltage·using this formula··Vref *·analog reading / 4096
I am only getting for an output the number·" 2 ".
CODE:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Pin Assignments
CS····· CON·· 9······· ' Chip Select
DIO_10· CON·· 10······ ' Data I/O pin 10
CLK···· CON·· 11······ ' Clock
' LTC1298 configuration
AD····· VAR·· Word···· ' Variable to hold 12-bit AD result.
config· VAR·· Nib
v······ VAR·· Byte
HIGH CS··············· ' Deactivate ADC to begin.
HIGH DIO_10··········· ' Set data pin for first start bit.
again:
· GOSUB convert···················· ' Get data from ADC.
· GOSUB calc_volt
· DEBUG· "A/D Reading: ",DEC AD,CR
· DEBUG· "volt Reading: ",DEC v, CR
· PAUSE 500······························· ' Wait a half second.
GOTO again································ ' Endless loop.
Calc_Volt:
v = 5 * AD / 4096
convert:
config = config | %1011
· LOW CS·································· ' Activate the ADC.
· SHIFTOUT DIO_10,CLK,LSBFIRST,[noparse][[/noparse]config\4]· ' Send config bits.
· SHIFTIN DIO_10,CLK,MSBPOST,[noparse][[/noparse]AD\12]······ ' Get data bits.
· HIGH CS································· ' Deactivate the ADC.
RETURN···································· ' Return to program.
Results:
A/D Reading: 2129
volt Reading: 2
A/D Reading: 2128
volt Reading: 2
A/D Reading: 2126
volt Reading: 2
A/D Reading: 2130
volt Reading: 2
A/D Reading: 2126
volt Reading: 2
I tired putting "DEC3" instead of "DEC" on the Debug volt reading line and I got this:
A/D Reading: 2127
volt Reading: 002
A/D Reading: 2129
volt Reading: 002
A/D Reading: 2127
volt Reading: 002
A/D Reading: 2128
volt Reading: 002
A/D Reading: 2129
volt Reading: 002
Any Suggestions on what I should try?
CODE:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Pin Assignments
config· VAR·· Nib
v······ VAR·· Byte
again:
· GOSUB calc_volt
Calc_Volt:
v = 5 * AD / 4096
convert:
Results:
A/D Reading: 2129
volt Reading: 2
A/D Reading: 2128
volt Reading: 2
A/D Reading: 2126
volt Reading: 2
A/D Reading: 2130
volt Reading: 2
A/D Reading: 2126
volt Reading: 2
A/D Reading: 2127
volt Reading: 002
A/D Reading: 2129
volt Reading: 002
A/D Reading: 2127
volt Reading: 002
A/D Reading: 2128
volt Reading: 002
A/D Reading: 2129
volt Reading: 002
Try multiplying your equation by 100, and then the output should be 225.
Then, you could print that, or if you really wanted to, parse it and add a "."
That is not the problem though. In convert use this equation instead of 5*AD/4000:
v = 8000 ** AD
Then the answer when AD=2129 will be 259, which you can display with a decimal point...
DEBUG "volt Reading: ",DEC v/100,".",DEC2 v, CR
Why 8000 ** AD? That is the same as 8000/65536, where the division by 65536 is implied in the ** operator. And the fraction you want is 500/4096 = 8000/65536.
Need more accuracy for roundoff? Use
v = 40000 ** AD * 2
DEBUG "volt Reading: ",DEC v/1000,".",DEC3 v, CR
Tracy Allen
www.emesystems.com
I will give your suggestion a try.
The results were:
A/D Reading: 2128
volt Reading: 0.03
A/D Reading: 2129
volt Reading: 0.03
A/D Reading: 2129
volt Reading: 0.03
A/D Reading: 2126
volt Reading: 0.03
A/D Reading: 2127
volt Reading: 0.03
A/D Reading: 2125
volt Reading: 0.03
A/D Reading: 2126
volt Reading: 0.03
A/D Reading: 2126
volt Reading: 0.03
A/D Reading: 2127
volt Reading: 0.03
A/D Reading: 2127
volt Reading: 0.03
A/D Reading: 2129
volt Reading: 0.03
A/D Reading: 2124
volt Reading: 0.03
A/D Reading: 2129
volt Reading: 0.04
A/D Reading: 1882
volt Reading: 2.02
A/D Reading: 1874
volt Reading: 2.02
A/D Reading: 1869
volt Reading: 2.02
A/D Reading: 1852
volt Reading: 2.02
A/D Reading: 1835
volt Reading: 2.02
A/D Reading: 1826
volt Reading: 2.02
A/D Reading: 1806
volt Reading: 2.02
A/D Reading: 1789
volt Reading: 2.02
A/D Reading: 1781
volt Reading: 2.02
A/D Reading: 1773
volt Reading: 2.02
A/D Reading: 1764
volt Reading: 2.02
A/D Reading: 1759
volt Reading: 2.02
A/D Reading: 1754
volt Reading: 2.02
A/D Reading: 1742
volt Reading: 2.02
A/D Reading: 1721
volt Reading: 2.02
A/D Reading: 1703
volt Reading: 2.02
A/D Reading: 1698
volt Reading: 2.02
A/D Reading: 1687
volt Reading: 2.02
A/D Reading: 1677
volt Reading: 2.02
A/D Reading: 1673
volt Reading: 2.02
A/D Reading: 1672
volt Reading: 2.02
A/D Reading: 1672
volt Reading: 2.02
A/D Reading: 1666
volt Reading: 2.02
A/D Reading: 1664
volt Reading: 2.02
A/D Reading: 1657
volt Reading: 2.02
A/D Reading: 1660
volt Reading: 2.02
A/D Reading: 1655
volt Reading: 2.02
A/D Reading: 1648
volt Reading: 2.02
So now I only have 1 problem how do I get the Volt Reading to Change along with the A/D Reading at the same time it Changes?
As you can see from the results above the A/D readings are changing but the volt Reading remains the same.
CODE:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Pin Assignments
CS CON 9 ' Chip Select
DIO_10 CON 10 ' Data I/O pin 10
CLK CON 11 ' Clock
AD VAR Word ' Variable to hold 12-bit AD result.
pH VAR Word ' pH value of the water
config VAR Nib
v VAR Byte
v2 VAR Byte
HIGH CS ' Deactivate ADC to begin.
HIGH DIO_10 ' Set data pin for first start bit.
again:
GOSUB convert ' Get data from ADC.
GOSUB calc_volt
DEBUG "A/D Reading: ",DEC AD,CR
PAUSE 500 ' Wait a half second.
GOTO again ' Endless loop.
Calc_Volt:
v = 8000 ** AD
v2 = v * 100
RETURN
convert:
LOW CS ' Activate the ADC.
SHIFTOUT DIO_10,CLK,LSBFIRST,[noparse][[/noparse]config\4] ' Send config bits.
SHIFTIN DIO_10,CLK,MSBPOST,[noparse][[/noparse]AD\12] ' Get data bits.
HIGH CS ' Deactivate the ADC.
RETURN ' Return to program.
And these Results:
A/D Reading: 1547
volt Reading: 1.88
A/D Reading: 1544
volt Reading: 1.88
A/D Reading: 1545
volt Reading: 1.88
A/D Reading: 1548
volt Reading: 1.88
A/D Reading: 1549
volt Reading: 1.89
A/D Reading: 1550
volt Reading: 1.89
A/D Reading: 1551
volt Reading: 1.89
A/D Reading: 1546
volt Reading: 1.88
A/D Reading: 1552
volt Reading: 1.89
A/D Reading: 1556
volt Reading: 1.89
A/D Reading: 1555
volt Reading: 1.89
A/D Reading: 1556
volt Reading: 1.89
A/D Reading: 1556
volt Reading: 1.89
A/D Reading: 1561
volt Reading: 1.90
A/D Reading: 1558
volt Reading: 1.90
A/D Reading: 1561
volt Reading: 1.90
A/D Reading: 1778
volt Reading: 2.17
A/D Reading: 1781
volt Reading: 2.17
A/D Reading: 1778
volt Reading: 2.17
A/D Reading: 1763
volt Reading: 2.15
A/D Reading: 1766
volt Reading: 2.15
A/D Reading: 1761
volt Reading: 2.14
A/D Reading: 1761
volt Reading: 2.14
A/D Reading: 1775
volt Reading: 2.16
A/D Reading: 1761
volt Reading: 2.14
A/D Reading: 1757
volt Reading: 2.14
A/D Reading: 1754
volt Reading: 2.14
A/D Reading: 1757
volt Reading: 2.14
without having to make a new line everytime there's a new value. I just want 2 lines of results:
1 - A/D reading
1 - volt reading
That keep changing values without having the results keep listing like in my post above
DEBUG CRSRXY, #, #
Where #,# is the x, y location (column, row I think - and they start at 0) You don't have to reprint the whole line either, just the part that changes.
- Rick
DEBUG HOME, "A/D Reading: ",DEC AD,CLREOL,CR
DEBUG "volt Reading: ",DEC v/100,".",DEC2 v,CLREOL,CR
You can read about the control characters in the manual along with the DEBUG command.
Tracy Allen
www.emesystems.com
