Problems with SPIN Code
Hello all folks,
I write the following code:
{{ Output.spin }}
VAR
long StackToggle24[noparse][[/noparse]18] 'Stack space for new cog
long StackToggle26[noparse][[/noparse]18] 'Stack space for new cog
OBJ
T24 : "Toggle24"
T26 : "Toggle26"
PUB Main
{{Start new blinking process in new cog}}
cognew(T24.Toggle24, @StackToggle24)
cognew(T26.Toggle26, @StackToggle26)
'the same result
'T26.Toggle26
'T24.Toggle24
'And I create two objects:
'Toggle24.spin
'and Toggle26.spin
PUB Toggle24
{{Toggle Pin, Count times with DelayMS milliseconds in between. If Count = 0, toggle Pin forever.}}
dira[noparse][[/noparse]24]~~ 'Set I/O pin to output direction
repeat
'Repeat for Count iterations
!outa[noparse][[/noparse]24] ' Toggle I/O Pin
waitcnt(4_000_000 + cnt) ' Wait for Delay cycles 'Clear Cog ID variable
PUB Toggle26
dira[noparse][[/noparse]26]~~ 'Set I/O pin to output direction
repeat 'Repeat for Count iterations
!outa[noparse][[/noparse]26] ' Toggle I/O Pin
the chip switched not from one cog to other
only the first object method a execute.
What's wrong please help me???
Best Regards: Uwe Reinersmann
Post Edited By Moderator (Chris Savage (Parallax)) : 6/4/2007 8:04:52 PM GMT
{{ Output.spin }}
VAR
OBJ
T24 : "Toggle24"
T26 : "Toggle26"
PUB Main
'the same result
'T26.Toggle26
'T24.Toggle24
'Toggle24.spin
'and Toggle26.spin
PUB Toggle24
repeat
PUB Toggle26
please see my comment in the other thread and remove this one to avoid problems of double posting.
http://forums.parallax.com/showthread.php?p=654046
Thomas
