LTC1298 connected to Basic Stamp 2 and question about the AD0831 and AD592
··· Is there some kind of special way to wire the LTC1298 ADC converter to the basic stamp 2 in order to get adc to read correctly? I have been trying for 4 months to get this converter to work and I have had no luck.· I had a LM35DZ temperature sensor connected to the ADC then to the basic stamp 2. I figured all I needed to do for the ADC was apply 5volts,ground and the input from the sensor to 1 of the 2 channels on the ADC but I still get an incorrect reading. Anyway's I have had enough with this analog to digital converter.
So I am thinking of buying the ADC0831 and AD592 temperature sensor from parallax.
Is the Analog to Digital Converter 0831 easier to use with basic stamp 2?
www.parallax.com/dl/docs/prod/appkit/ltc1298.pdf
' {$STAMP BS2}
' {$PBASIC 2.5}
' Pin Assignments
CS CON 9 ' Chip Select
DIO_10 CON 10 ' Data I/O pin 10
CLK CON 11 ' Clock
' LTC1298 configuration
config CON %1011 ' Configuration bits for ADC.
AD VAR Word ' Variable to hold 12-bit AD result.
pH VAR Byte ' pH value of the water
HIGH CS ' Deactivate ADC to begin.
HIGH DIO_10 ' Set data pin for first start bit.
again:
GOSUB convert ' Get data from ADC.
DEBUG "A/D Reading: ",DEC AD,CR
PAUSE 500 ' Wait a half second.
GOTO again ' Endless loop.
This basically just keeps reading the 12-bit binary number and displays it on the screen.
So what I want to do now is convert the Binary number that the ADC puts out into Voltage.
Then take that voltage and divide it by 0.25. Any Ideas?
Is there an analog to digital converter that reads millivolts?
- Rick
with a Linear +10.0 mV/°C Scale Factor
I am using a LM35DZ sensor: http://www.national.com/ds/LM/LM35.pdf
Post Edited (pimp200277) : 6/5/2007 4:11:39 PM GMT
I think there’s a sensor version in·NSC's LM series that does degrees kelvin which might be a bit easier to use.
On the other hand, do you really need the entire -55C to +155C range?
- Rick
Ok, I will just take a op-amp and build an amplifier circuit and input the sensor output in·Millivots·into the circuit to get from Miilivolts to a Volts output then input the volts into the LTC1298.
Post Edited (pimp200277) : 6/5/2007 10:03:27 PM GMT
For a fish tank you will use a small segment of the range, but there is no need for an amplifier. Just put the output from the LM35DZ right into an LTC1298 input. Then use a formula the same as the one I gave you for pH, to convert the raw count into degrees Celsius, with a resolution of 0.1 degree:
The resolution of the converter is 1.2207 mV, which translates to about 0.1 degree Celsius. That is good enough even for salt water tropical fish. The LM35DZ will need to be calibrated against a more accurate thermometer, if you really need accuracy.
Tracy Allen
www.emesystems.com
