If you describing the Propeller Proto Board Stock#: 32212, you will need to connect whatever I/O you want to the servo port. Only Ground and Power (+5 or VIN) is provided on the servo port. Here's a link to the schematic.
Definetly a E3 (Electronics Engineer Extrodinare!)
"I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
http://www.parallax.com/dl/docs/prod/prop/Propeller-ProtoBoard-v1.1.pdf
