Role of Transisor in the Basic stamp 2 chips
I am wanting to make a home board using PIC16C57C-20/P, I have tried the circuit as indicated in the Schematic given in the parallax site for BS2OEM schematic, I had made the circuit on the breadboard except for the Brown out Detector, When ever I tried to download program in the PIC it is not doing, please tell why it is happening and also tell how the RS232 Logic is being converted into TTL logic in BS2 and also how the PIC16C57C is put into ICSP mode.
Aravind kumar singh
Aravind kumar singh
But they're not completely heartless. They will sell you a PIC16C57 WITH the PBasic runtime environment programmed in -- that's the "OEM PIC" processor they have on their website.
To jumpstart your efforts, it might be good for you to purchase the OEM Kit from Parallax. This will have all the necessary parts -- and you can then find other sources for the non-Parallax parts if you want to make a lot of them.
But yes, an off-the-shelf PIC16C57 won't have the runtime code programmed into it.
And what are the pins from the DB9 cable required to download the program form the Pc to the Chip using serial port....?
