LCD Issues
I have the Parallax 2x16 Serial LCD. I set it up on the breadboard, and it worked. I soldered it to my circuit board, and only the cursor is displayed. I think it is getting power, but the RX signal is messed up. I've tripled checked every connection...
Does the single cursor mean anything in particular?
Thanks!
Thanks!
thanks!
- Stephen
Is the LCD Backlit? If so you’ve definitely exceeded the current you can draw from the BS1 on-board regulator. If not, you’re probably still pretty close. Also there must be an error in your schematic as the LCD and BS1 never get connected to the battery negative terminal, yet your LCD is at least partially coming on.
Thanks!!
EDIT: I completely rewired it... and fixed [noparse]:)[/noparse]
Post Edited (ghost13) : 6/3/2007 7:41:36 PM GMT
