Converting 12V to 5V signals
Hi, recently i was given a working mechanism that runs on a 12v signal processor, the processor components were damaged and I was planning to use Basic Stamp 2 to replace it which·works with·on 5V signals. I would like to know if there is any suitable·way to convert the·signals from 12volts to 5volts?
Use this calculator to find the resistors you need
Example 12V input with a 470 ohm and 335.71 ohm divider gives you a 5V signal.
Adjust the resistors for the current you need. The example above will give you 15ma signal the basic stamp can read.
http://www.raltron.com/cust/tools/voltage_divider.asp
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Post Edited (Mike Green) : 5/31/2007 2:23:06 PM GMT
