transfer spin to assem — Parallax Forums
ratronicratronic Posts: 1,451
edited 2007-05-31 14:46 in Propeller 1
I am trying to pass a number from a spin top obj to an assm servo obj following Graham's data transfer in the
assm step by step routines for an example. My top spin = h48c and the objects I am is using a trimmed down
version of the a48c Tri-axis accelerometer and my own serv1 servo object. I am using 1.5 ms for center. That's
the problem I am having is taking the y axis raw # (which I am) and adding 120000 to it (which I can) and sending it to my serv1 routine (where I am having the problem). I only get the start time # I started it with (1.5ms) . The off time is always set at 20ms. I have tried everything I can think of but I can't seem to update
the on time # (starts with 1.5ms) with y axis # with 120000 to it from the accelerometer routine.· Can anybody look at my code
and tell me why I am going wrong? My end result is I am at the start of a balancing bot and I know I have far to go but this is holding me up. Thanks Dave.
Fix it if ain't broke·
D Rat
Dave Ratcliff· N6YEE
  • Beau SchwabeBeau Schwabe Posts: 6,573
    edited 2007-05-31 03:42
    ratronic,
    Take a closer look at your 'H48C obj.spin' program·and make sure it is·providing the correct return values for 'H48c.y'.... I modified your 'ah48c.spin' to look like this...
    [b]'ah48c.spin[/b]
    [b]con[/b]
         [b]_clkmode[/b] = [b]xtal[/b]1 + [b]pll[/b]16x
         [b]_xinfreq[/b] = 5_000_000
    [b]obj[/b]
        sr : "serv1"
    '   lcd : "debug_lcd"
    '  h48c : "h48c obj"
    [b]var[/b]
    [b]long[/b] ya
    [b]pub[/b] main
         sr.start(120000)
    '     h48c.start(2,0,1)
    '     lcd.start(6,19200,4)
    '     lcd.backlight(true)
    '     lcd.cursor(0)
         [b]repeat[/b]
    '       ya := h48c.y + 120000
           ya := 120000
           sr.out(ya)
    '       lcd.cls
    '       lcd.dec(ya)
           [b]waitcnt[/b](15000000 + [b]cnt[/b])
    ... After connecting a scope to pin #7 and manually changing values for 'ya' , the 'serv1.spin' program you provided appears to function properly.
    Hope this helps toward diagnosing your problem.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 5/31/2007 3:47:09 AM GMT
    edited 2007-05-31 04:08
    Beau , I see that you fixed the # by adding the line ya := 120000 , I am trying to update the y axis + 120000. I get that # ok.
    My problem is sending the 120000 + y axis which varies by the position of acc chip which is about in the range of +or- 250 +
    120000. I can get the total # and display it. But I can't seem to send it to the serv1 object. It doesn't vary the on time of 120000 I started the object which. I can see on the scope it stays at 120000 I started it whith.?
    D Rat
    edited 2007-05-31 04:40
    ratronic,
    "I see that you fixed the # by adding the line ya := 120000 , I am trying to update the y axis + 120000. I get that # ok."
    Right, I understand that, my test was to make sure that the serv1 object was indeed working properly. Changing ya to 80000 produced a pulse width of 1000uS ...
    likewise changing ya to 160000 produces a pulse width of 2000uS.
    If the values returned from 'h48c.y' only ranges from +or- 250 then that is likely your problem....
    250 + 120000 = 120250 ... divide this by 80 and you get·1503.125 uS for a pulse width
    -250 + 120000 = 119750 ... divide this by 80 and you get·1496.875 uS for a pulse width
    ...a deviation of only 6.25uS is barely enough for a standard servo to register any change at all. Looks like the value returned from h48c.y needs to be scaled to something
    the servo can actually recognize.
    Beau Schwabe
    IC Layout Engineer
    Beau, I figured it out thank you! You were right the raw y axis # was so small no wonder I didn't see it at all on the scope. So what I did is multiply the y axis x 160 then add 120000 to it. Now I can see it on the scope! I now get a range that goes· +/- .5 ms difference from 120000. Thanks for pointing me in·the wright direction!! I have attached corrected code if you want look at it. Thanks again!! Dave
    D Rat
