formatting data from Scrath Pad RAM — Parallax Forums
Jon LoldrupJon Loldrup Posts: 14
edited 2007-05-30 20:23 in BASIC Stamp
Hi
After loading some position-data from my GPS into SPRAM, I am wondering how to convert it to integers?
I can easily put it into the register:
myVariable VAR Byte
GET 0, myVariable
but when I want to convert it to integer:
myOtherVariable VAR Byte
myOtherVariable = DEC myVariable
I am not allowed [noparse]:([/noparse]
How can i EVER do calculations on a digit stored as ASCII-code? Poor me cry.gif
(by the way, if I manage to convert it, and I want to substract two latitudes from each other, I will still have to implement the substraction-algorithm myself, looping through individual bytes containing the individual digits of the position, as a word cannot contain the whole position. Is there no easier way?)
/jon
/jon
    edited 2007-05-30 19:53
    You have to do the ASCII digits to integer conversion yourself. A simple loop will do:
    theDigit var byte
    theValue var byte
    position var byte
    convert:
    theValue = 0
    position = 0
    loop:
    get position,theDigit
    position = position + 1
    if (theDigit < "0") or (theDigit > "9") then exit
    theValue = theValue * 10 - (theDigit - "0")
    goto loop
    exit:
    Note that you can also use DO ... LOOP and other neater constructs.
    This stops at the first non-digit and leaves position at the address of
    the next character after the delimiter. If you need a word value, just
    define theValue as a word instead of a byte.
    edited 2007-05-30 20:13
    Hello,
    A complete article describing this can be found at the following link. Take care.
    http://www.parallax.com/dl/docs/cols/nv/vol4/col/nv103.pdf
    also
    http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv83.pdf
    edited 2007-05-30 20:17
    Jon,
    Your query relates directly to some PBASIC enhancements I've begun lobbying for: http://forums.parallax.com/showthread.php?p=652397. As BASIC Stamps are used more and more to deal with serial protocols, it would be helpful if the language supported buffer transfers/encoding/decoding in a more I/O-like fashion. Mike's technique will certainly work, but with enhanced language features it wouldn't be necessary.
    Please note also that Mike’s code will only run under 2.0 syntax on the BASIC Stamp Editor since reserved words under 2.5 were used. Take care.
