Stamp Editor wnats CD — Parallax Forums
EnriqueEnrique Posts: 90
edited 2007-05-30 20:05 in Robotics
I just received my Boe-Bot, I am assembling it and I installed the BASIC Stamp Editor from the CD that came with the kit. When I run the editor while the CD is not in the drive I get a message stating that there is no disk in the D drive (which happens to be my CD-ROM).
How do I get rid of this message?
Enrique
  • Skywalker49Skywalker49 Posts: 172
    edited 2007-05-30 09:01
    Enrique,
    you are not the only one who experience(d) this problem.
    have a look at this thread:
    http://forums.parallax.com/forums/default.aspx?f=5&m=183010&g=183510#m183510
    edited 2007-05-30 15:43
    If you recently opened a file from the CD it may just be that the link is still in your recent documents list and could be causing the problem. It should clear up after a while if this is the case. Take care.
  • EnriqueEnrique Posts: 90
    The problem went away by itself, the recently used files list was the problem as predicted.
