Proto board problem
I am desperate and need some help.
I am using the Parallax Proto Board with a USB2SER
I am trying to drive a GWS servo model S03N as channerl·1 of the Proto board.
I am using the "servo32" object.
a PING and a ezLCD-004 LCD·are also connected.
The PING runs OK until the servo is connected, then stops working and the servo jerks and stand still.
The same thing happens with a GWS servo model PARK L.
I am attaching the code.
spin
13K
the prop has reset. The reason you want to do this is there are a lot of things that can reset the prop (including servo current
draw, brownout on the supply due to low batteries, transients from motors picked up by wiring, etc.) Making every program
start with a recognizable blink or buzz will save you tons of time.
Paul Baker
