Proto board memory?
I just got my 5-pack of proto boards (yay, nice and small!) one of which will end up piloting a solar-powered pontoon boat used to take water samples from various areas of a lake.
Quick question: The specs say it comes with a 64K rom chip... now I know we get about 32K of ram on the Prop, so is it safe to access the other 32K (with an i2c routine I guess) to do data logging and so on? I'd rather be told before I fry the chip by trying to talk to it [noparse]:)[/noparse]
Also, what's the overhead for the eeprom file? (as in, what's the first addresss I can peek/poke at on the rom chip -- somehow I doubt it's $8000, there usually is some padding...)
http://forums.parallax.com/showthread.php?p=650217
meow, i have my own topic now? (sorta)
There's no file system. You just have 32K of space that you can use as you want. The first address is indeed $8000.
There are several sets of I2C routines available. There are two sets in the Object Exchange and another that's part of the Propeller OS and FemtoBasic/BoeBotBasic (also in the Object Exchange). Any of them should work although some have had problems with "i2c Object and examples" when used with a boot EEPROM (like on the Protoboard).
Post Edited (Mike Green) : 5/28/2007 6:36:25 PM GMT
