Programming baudrate
Is it possible to program the Javelin stamp with a serial bluetooth adapter with one of the folowing baudrates?
4800bps
9600bps
19200bps
38400 bps
57600 bps
115200 bps
230.4 kbps
460.8 kbps
2 TxD Output Transmitted data
3 RxD Input Received data
5 GND N/A Signal ground
7 CTS Input Clear to send (Remarks)
8 RTS Output Request to send (Remarks)
9 Vcc Input Power supply
Thanks!
4800bps
9600bps
19200bps
38400 bps
57600 bps
115200 bps
230.4 kbps
460.8 kbps
Thanks!
To communicate with the javelin you use an Uart object and you can select
from multiple baudrates. But this is not·to program the javelin.
regards peter
