Simple_serial speed problem
Please can someone take a look at my code and tell me why I'm unable to communicate above 4800 baud using simple serial. I'm loading the program into the hydra and using the programming connection to connect to my PC. I have used 3 different pieces of modbus testing software which all work fine at 4800 baud or below. I would like to communicate at a bit more than that. I understand that simple_serial can communicate up to 19.2kps. I have also tried fullduplexserial, which I am unable to get working at all. If anyone can point me in the right direction that would be great.
Damo
Damo
http://forums.parallax.com/showthread.php?p=650217
meow, i have my own topic now? (sorta)
As for electrical noise my hydra is about a metre away from my PC and is surrounded by nothing electrical. The usb lead travels in free air to the PC.
Damo
I will try the COPIO driver and let you know how i get on.
Damo.
By the way has anybody had the chance to try the code??
Damo
