GEAR: TV plug in trouble.
potatohead
Essentially, it syncs poorly to many images --even when they plenty close enough to NTSC spec.
Any tweak ideas?
Edit: Is the plugin scheme documented anywhere? I've been playing with the TV plugin code and it does some averaging to detect where the sync is happening. I believe this is the trouble for some images. I think I need more to modify this plugin code.
Post Edited (potatohead) : 5/28/2007 5:29:26 PM GMT
Any tweak ideas?
Getting the plugin to work boils down to making sure it is watching the same pins you are generating video on. Change this section:
Voltage =
((pins[noparse][[/noparse]24] == PinState.OUTPUT_HI) ? 1 : 0) +
((pins[noparse][[/noparse]25] == PinState.OUTPUT_HI) ? 2 : 0) +
((pins[noparse][[/noparse]26] == PinState.OUTPUT_HI) ? 4 : 0);
The numbers shown are for HYDRA. To make the edits, open plugin from the main menu, not the one that displays when an EEPROM is loaded. You can also just open the .xml file too and make changes there.
After matching the pins up, load your EEPROM file, hit run, then hit open plugin, click on the TV tab and wait.
Thanks for your reply. Sorry I missed it. It's my own circuit with the same video dedicated pins as the demoboard. What do I put in that case?
Thanks.
The steps are:
1. Build your EEPROM file
2. Open it up in GEAR
3. Open the plugin, using the menu that appears after you open your EEPROM file.
4. Hit run and that's really it.
