Industrial Controls - Digital Input Signal Conditioning
I am having a problem with experiment #2 exercise 4 page 49-50.· It wants me to calibrate the presence of an object by measuring between the collector and emitter of the phototransistor and recording the readings - which I have done.· But then it wants to adjust the potentiometer to provide proper reference voltage which is halfway between my high and low reading.· The problem is that the voltage does not adjust while measuring across the collector and emitter of the phototransistor.· It does adjust when I measure between pins 3 and 8 of the LM358.
I have rechecked the circuit and it appears to be correct.
My phototransitor Voltage with no object: 4.55vDC
··········································with Object: 4.10vDC
Both cases the LM358 output voltage is 0vDC when measuring pin 1 of the LM358 to ground.
I am looking for clarification on this part of the excerise because it seems that I am doing something wrong.
Any thoughts?
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
Any thoughts?
What you need is to adjust the potentiometer so that it is at a voltage of 4.3V as referenced to ground (Vss).· This is the reference voltage.· When collector voltage is above 4.3V, the output (pin 1) of the LM358 should be near 5V.· When below 4.3V, the output should be 0V. When the fan is running, it will produced pulses that should be read as counts by the BS2.
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
-Martin
