Using RFIDs with a safe
For my next BS1 project, I want to use the RFID reader to create a safe. I have it all figured out, except for the locking mechanism. Is there a special motor lock? Or do I just attach a bolt to the shaft of a bolt and have it lower and raise it?
Thanks!
Thanks!
One project I did was for a keypad lockable tool cupboard where the door mechanism was controlled by a rotary knob, i merely made a metal wedge that operated by a solenoid and jammed the levers attached to the knob stopping the knob from being able to rotate and open the door. One thing·that tends to get overlooked·in this type of project is a backup means of opening the safe, Battery backup in case of power cut or a mechanical bypass by key.
Up and down would be great, but I'm worried about timing it perfectly (relocking might be tricky).
Thanks!
You might try asking a lock-smith, they might be able to give you more information.
