Basic Stamp Stepper Controller
Hi everyone
I am currently working on a project to automate a piece of industrial equipment. (A common topic around this forum). I was planning on driving a ball screw with either a stepper motor or servo motor.·The final goal is to have a Visual Basic application output a signal (the position requested) to a stamp and then have the machine home itself to the requested position. Does anyone have any suggestions on the best way to do this?
I am leaning towards using·this stepper motor: http://www.kelinginc.net/KL34H280_55_4A.pdf
Thank you for your help.
-Pat
-Pat
2) Stepper motors do slip. You will want to recalibrate your position on power up and occasionally if you leave the device powered up for a long time. You can use the limit switches for this if they're accurate enough.
Post Edited (Mike Green) : 5/27/2007 7:59:49 PM GMT
Would I be better off with a servo motor and a rotary encoder?
The continuous motion servos won't give you the kind of control you would want.
You could use a dc motor and rotary encoder or the stepper motor. The dc motor
would also need an external driver that you could buy or build.
Stepper motor drivers are not hard to build (www.aaroncake.net/circuits/stepper.asp)
and (www.elabinc.com/ede1204.pdf).
If the power requirements are small, steppers (within their capabilities of speed and torque) are easiest to use.
Cheers,
Tom Sisk
http://www.siskconsult.com
