I do not own a sumo-bot, but from what I have read, I think its board·has a built in stamp and uses PBASIC.··If this is true·I do not see why it wouldn't work.· I am fairly certain that other people have asked the same or similar questions.· Also, check the manual to see if anything conflicts.· Try searching the forums.· You are talking about the IR remote kit for the boe-bot, right?
The Sumo-Bot uses the same IR detectors as are used for IR remote control reception, so the hardware is already present. You might want to add an additional IR detector on a spare I/O pin with a wider range of view for use only with the remote. You would need to add software for IR decoding to the existing Sumo-Bot program that you're using. The tutorial "IR Remote for the Boe-Bot robot" (here: www.parallax.com/html_pages/downloads/siccurriculum/documentation_sic_curriculum.asp) shows you how it all works and gives sample code.
yes any remote will work you just have to change the program a bit to make an accomodation for the different signal, i have done it with many different remotes
D Faust
