Serial LCD Backlight Problems
I have the Prallax 2x16 Serial Backlit LCD. I programmed it as instructed, but the backlight doesn't turn on until after the first cycle. And after the 1st cycle, it doesn't stay on... it flashes rapidly and no text is displayed. My code is attached.
Any help is appreciated.
THANKS!!!
THANKS!!!
Is this my fault?
I think that it should be,
You needed to put the dollar sines in front of the numbers so that is shows that they are HEX numbers
My computer, http://forums.parallax.com/showthread.php?p=630466
I tried that, and no luck. Here's my example code:
SEROUT 3, T2400, ($22, $12, $17) SEROUT 3, T2400, ($17) PAUSE 5 SEROUT 3, T2400, ("Insert into the", $13, "test chamber.")It also displays the quote mark in ""Insert into the"" and ""test cahmber""
Also, how do I print a variable's value?
It was declared like this:
Any help would be awesome!!!
how do you display variables?
Thanks!
(I'm using the BS1)
EDIT: Problem solved
Post Edited (ghost13) : 6/1/2007 12:06:19 AM GMT
