RF Modules Tranceiver on ONE Antenna
Chicago Mike
SO the RF modules are great, but I'm looking at making a project into a smaller package, and I'm interested in using ONE antenna instead of the 2 (One for receive and one for transmit. Yes, the unit needs to be a transceiver). From reading the cut sheets on the Linx site (The RF chip parallax uses in these modules), its not recommended to simply tie the ant. pin of the RX and the TX units to one antenna, because during transmit it will overpower the receiver. Does anyone have experience with this? Obviously this is done commonly on many products (Cordless phones being the most basic). Linx recommends using an Antenna Switch, but I can't seem to find any of these for the 433Mhz product range?
I'm fine with setting up a handshaking routine to check for collisions, so I don't attempt to send and receive at the same time on the unit, but I'm more worried about the electrical side (and the warning the Linx says about this).
Anyone try this before? Its more that I don't want 2 antennas sticking out of the package, but I also don't want to damage the RX module.
Thanks!
Post Edited (Chicago Mike) : 5/26/2007 11:23:31 PM GMT
Thanks!
There are other transmit/receive switches using PIN diodes that you could use, but I don't have any links.
You might try searching the web for PIN diode transmit receive switch circuits for UHF frequencies like 433MHz.
Here are some;
www.active-robots.com/products/radio-solutions/radio-modules.shtml
www.saelig.com/miva/merchant.mvc?Screen=CTGY&Category_Code=RW
www.sparkfun.com/commerce/categories.php?cPath=16_114
To get longer distance, you put an amp inline, at the cost of power usage..
Bob N9LVU
Why do half-duplex when you can have full-duplex with two antennas? I suspect PJ Allen is correct, the antenna switching may take up as much space as a second antenna. After all at 418Mhz, a 1/4 wave antenna is merely 7" of wire above a small ground plane.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
