Simple problem with program
Hello, I've been using PBasic and have just been going though my programs making them work with the SX, I've changed a simple one that flashes a couple led going though a transistor, and one just going though a 470ohm resistor.· The problem is I have 2 programs and one works and one doesn't and I can't see why the 1st doesn't.· My schematic is attached for the pin with the transistor.· Can anyone tell me what I'm overlooking?
Program 1:
' Device Settings
DEVICE········· SX28, OSCHS3, TURBO, STACKX, OPTIONX
IRC_CAL··IRC_SLOW
FREQ··········· 5_000_000
PROGRAM··start_point
' IO Pins
'pin0 to transistor and 3 leds
'pin1 to resistor and 1 led
' Variables
ctn·var·byte
TRIS_B=0
RB=0
'··········· PROGRAM CODE
start_point:
·for ctn =1 to 10
··RB=%00000000
··pause 100
··RB=%11111111
··pause 100
·next
·goto start_point
Program #2
'·· File...... TEMPLATE.SXB
'·· Purpose... SX/B Programming Template
'·· Author....·
'·· E-mail....·
'·· Started...
'·· Updated...
' Program Description
' Device Settings
IRC_CAL··IRC_SLOW
' IO Pins
'Pin0 to transistor and 3leds
'Pin1 to resistor and 1 led
' Variables
CNT·VAR·BYTE
spd·var·byte
·' INTERRUPT
' Program Code
start_point:
·spd =·10
·TRIS_B=0
·RB=0
FOR CNT = 1 TO 250
·RB=%01111110
PAUSE spd
·RB=%11111101
PAUSE spd
NEXT
goto start_point
Program 1:
' Device Settings
IRC_CAL··IRC_SLOW
' IO Pins
' Variables
ctn·var·byte
TRIS_B=0
RB=0
start_point:
·for ctn =1 to 10
··RB=%00000000
··pause 100
··RB=%11111111
··pause 100
·next
·goto start_point
Program #2
'·· Author....·
'·· E-mail....·
'·· Started...
'·· Updated...
' Device Settings
IRC_CAL··IRC_SLOW
' IO Pins
' Variables
CNT·VAR·BYTE
spd·var·byte
·' INTERRUPT
' Program Code
start_point:
·spd =·10
·TRIS_B=0
·RB=0
FOR CNT = 1 TO 250
·RB=%01111110
PAUSE spd
·RB=%11111101
PAUSE spd
NEXT
goto start_point
bmp
30K
If you define your pins you can set them as output without having to use "TRIS_".
P.S. In your schematic you have the LEDs upside down, they won't light if they are connected as shown.
Bean.
“The United States is a nation of laws -· poorly written and randomly enforced.” - Frank Zappa
www.hittconsulting.com
Post Edited (Bean (Hitt Consulting)) : 5/26/2007 12:15:36 PM GMT
Thanks for catching my mistake! I knew it was something foolish!
Russ
Russ
iLed = (Vsource - Vled) / Rlimiter
so...
(5.0 - 3.2) / 470 = 0.0038
If you wanted to get 10 mA through the LEDs you can do that by dropping to a 180 ohm resistor. Since you're just getting started, let me recommend you get a copy of the Forrest M. Mims book, "Getting Started In Electronics" -- it will be a very big help as you move forward with your experiments.
Russ
