Force Gauge
Hello,
I work for a high altitude ballooning group - we are interested in measuring the force between the payload and the balloon (maybe 5-10 times a second) for the duration of a flight using the basic stamp & then some type of data storage such as some EEPROMs. Has anyone come across any writeups in the completed projects forum, or anywhere else that has relevant information. I would be interested to hear what instruments/gadgets other people have used to measure force, and how they have hooked them up to the basic stamp & collected data.
Thanks!
-cjkogan111
Thanks!
-cjkogan111
Tension load cells tend to be a bit pricey - $500+
I was looking for something under $100.
Also, if anyone has ideas about the data acquisition options, I would be interested.
Thanks!
-cjkogan111
have a look here: www.parallax.com/detail.asp?product_id=30056
Just a suggestion
Stefano
http://dkc3.digikey.com/PDF/T072/P2119.pdf
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
Post Edited (Martin Hebel) : 5/29/2007 6:34:05 PM GMT
Stefano - Is there any way to hook thing up easily so that I can measure tension with that device.
LSB - I will look into the accelerometer - thats a good idea.
Phil - Do you have any ideas about hooking the fish scale into a stamp?
Martin - Those parts look good, but do you know if they have a specs sheet? That link is just a catalog page, and it is hard to really know what you are buying until you get it.
Also, does anyone think that this strain gauge could work: http://www.vishay.com/docs/11305/500bh.pdf
Thanks again,
-cjkogan111
-Martin
Parallax sells a 3D-3G model (may be enough (?) as the balloon will soften shock) --completely and expertly documented. Also EEprom, of which you will likely need plenty!
Post Edited (LSB) : 5/30/2007 12:56:17 PM GMT
