BS2 and optoisolator
firestorm.v1
Using this optointerruptor http://www.datasheetcatalog.com/datasheets_pdf/G/P/1/A/GP1A50HR.shtml
I was trying to hook it up to the BS2 and I noticed that the BS2 was not receiving any signal from it. Additionally, my cellphone camera can detect IR when I fire several remotes to it and I don't see the opto LED light up in the device.
The way I have it hooked up: (disregard the periods, they're used for spacing, the ='s indicate conenctions)
..................................................Infrared LED
Vcc)=====(470 ohm resistor)====(pin 1)==|>|==(pin 2)====(another LED, non IR)==|>|==Gnd
Vcc)==================(Pin 3)===[noparse][[/noparse]Isolator]===(Pin 5)=====================GND
...............................................................(Pin 4)=====(220 ohm resistor)==========(IO pin 1)
.....................................................................\\========(10K resistor)=============GND
The 2nd LED remains lit, so I know that voltage is going through the IR side of the opto, but I get nothing out the other end and I don't get anything out of the little slit in the jacket. I reversed the leads going to the IR Led of the opto in case I had it backwards and the non IR led went out. I restored the original connection and the non IR led lit up again. On a hunch I took one of the remotes and aimed at the receiver of the opto and fired at it. The BS2 still did not respond with any value. My VOM also showed nothing on the sensor pin (pin 4). Does anyone have any suggestions on things I can check or did I cook the opto by accident?
http://www.parallax.com/detail.asp?product_id=350-00014
http://www.parallax.com/detail.asp?product_id=28139
Oh wow, that is much better.· I'll keep that in mind if I need to post a schematic or code in the future.
My concern is that the opto's LED is burned out, as I don't get any indication that it is emitting light. I'm not naieve enough to believe I can see infrared, but I have a camera that does.·It doesn't detect any light coming from the IR LED and I don't know what else I can do to try and troubleshoot this.
Any suggestions?
Thank you for your hint about the code window. I thought that was for HTML code..
