new spin stamp
I just ordered a new spin stamp chip!!!· This will give me 16 I/O pins!! I have a 40 pin prop chip and a demo board
This is going to fit the bill!!
Dave Ratcliff· N6YEE
D RatFix it if ain't broke·
We have a spin stamp, its main use so far has been as a "mini video toaster"... we built a little rig with a little composite-in LCD, a little parallel text LCD and two serial port inputs (one for a keyboard and one for a Xbee), it makes for a pretty nifty looking PDA [noparse]:)[/noparse]
it's a nice thing, but we had to paste a label on it saying "this is not a bs2, it runs on 3V, don't feed it 5", that's the only problem i can see with it really.
http://forums.parallax.com/showthread.php?p=650217
meow, i have my own topic now? (sorta)
It's the end of the month and I'm not broke for once, so I ordered a Spin stamp *and* finally bought myself a Hydra! With the lower prices, I only spent as much as I would have on the Hydra alone if I'd gotten it when it first came out.
Are you sure you're not referring to a third-party device?
Any pic's on you'r "video mini toaster?"
Can you post some code ?
Rob7
Paul Baker
And if not, I have a sneaky idea. Since I have a spare 339 comparator chip and a 12 volt supply, I could use the output of the comparator to generate a +12V signal on the serial line whenever the Spin Stamp's S-out pin goes to 3.3V, and use S-in pin and a diode & capacitor to generate a negative power supply for the 339 so it can go to -12 as well.
(Yeah yeah, I know, awful lot of trouble to go to to avoid using a Max 232. But, darn it, I never have any of the Max 232's around when I need them!)
Comparing the price of the spin stamp to the protoboard, does this come down to the cost of soldering those pins on? I know what you are going to say but I'd be happy to solder those on if I could buy the stamp at similar prices to the protoboard! I'd also buy a pack of 5 with no problems.
A further question, can you tell me the part number of the crystal if that's possible, I want to make some truly micro propeller set ups and it looks perfect.
Graham
Paul Baker
Post Edited (Paul Baker (Parallax)) : 5/26/2007 4:43:17 PM GMT
