Ideas- Thermal Conductor, Electrical Insulator, Waterproof
realitybias
I need ideas. We are using a nichrome-based wire heater element to heat up water, but stray current in the water from the exposed nichrome wire presents tough problems. I need an idea for a substance that could be wrapped around it, that will withstand the high temperatures that glowing nichrome wire can sometimes reach, while insulating the nichrome wire from stray electric currents. Any ideas?
The way you are set up now, I really hope you're using very low voltage!
Cheers,
Tom Sisk
http://www.siskconsult.com
They have many heaters in glass tubes. Also, check out the "Heater" section of Omega Engineering.
Tom Sisk
- Rick
They also cannot interfere electrically with other sensors that are submerged. Our nichrome wire heater, with exposed wire, heavily interfered with our other sensors.
You've all got good ideas... if we could find a cheap way to do this, either by coating the heater element in a thermo-conductive electrical insulator, or buying an implimentable comercial version, it would be great.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Solder on the wires
Dip the whole thing in epoxy
You say you are measuring conductivity.· Is the nichrome wire alterning the conductivity?·
Bean.
“The United States is a nation of laws -· poorly written and randomly enforced.” - Frank Zappa
www.hittconsulting.com
just a thought,
Marty
Tracy Allen
www.emesystems.com
I don't see why you need to bother with nichrome wire why not just use a chip resistor dipped in epoxy then you don't have to worry about overheating the element. If it's getting red hot now insulating the wire will only make it hotter and you will smoke any insulation to get the amount of heat you are getting now. You need to disburse the heat over a larger area. If you are heating water the maximum is 212 degrees F anyway, why do you need an element that puts out 1000F. With 16oz of water you need 1 BTU per degree of heat so from room temp to 212 is 242 BTU's
That's about 120 watts or energy over 1 hour. If you are only using 10 watts for 1 lb of water with no thermal loss you can get about 14 degrees increase over 1 hour from room temp. You need to reduce that by the thermal loss of the container holding the water.
Because the nichrome wire sent several stray currents through the system, it made the self regulation of the system impractical, and in some cases, damaging. I remember one groups boe bot started smoking, and they blew out a 555 circuit.
I found online a length of silicone-wrapped heater wire that can go up to 150 degrees C, which should be about right for our purposes.
The tubing can be bent in custom shape(s) to fit your needs..
It would be much better safer than silicon-wrapped heater wire...
There would be NO chance of stray currents inside of a glass envelope..
Also, the more wire you use, the lower the max temp of the wire to get the same
thermal ouput...
