What are Capacitors used for?
Hi, I am new at electronics please can you help me with what a Capacitors does, and what type of applications would you use them for and why?
Thanks everyone.
Thanks everyone.
Whit+
Capacitors can hold high voltage, and then be discharged very fast to make big sparks. Some capacitors are very expensive and can hold lots of energy, it's their ability to charge and discharge at very high rates that makes them different from a typical battery.
Look up FARAD , capacitors are rated in units of charge capacity based on the FARAD.
Be careful when working with even small ones as they can explode (if connected wrong) as some have plus and minus connections and connected backwards or too high of voltage can make them explode. The ceramic types can easily put your eye out at close range so ware safety glasses when experimenting. Shocks are not the only hazard when working with electronic devices. Smoke and fire can be made with 9V batteries as well.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Capacitors oppose changes in voltage between thier two pins, they like the voltage to remain constant. If it's not constant it will store charge across it's plates when the voltage increases (ie take away some of the current in an attempt to suppress the voltage) or will dump charge from its plates when the voltage decreases (ie add some current in an attempt to "prop up" the voltage). A capacitor isn't concerned with the current flowing and will make fluctuations in the current in its attempt to hold the voltage steady. The larger the value of the capacitor, the more effect it's effort has on the circuit.
Inductors oppose changes in current running through it, they like the current to remain constant. If it's not constant it will store charge in an electromagnetic field when the current increases (ie take away some of the current in attempt to suppress the current) or will dump charge from its field when the current decreases (ie add some current in an attempt to "prop up" the current). An inductor isn't concerned with the voltage across it and will make fluctuations in the voltage in its attempt to hold the current steady. The larger the value of the inductor, the more effect it's effort has on the circuit.
So you can see while inductors and capacitors are both devices capable of storing charge, the way they use that charge and it's effect on the circuit is different.
Paul Baker
Thanks that is just what I wanted to know thanks, I couldn't understand why you connected them right next to the chip's pins but it must be to keep the voltage straight on 5V.
Thank you.
Paul Baker
