Basic Stamp 2 Carrier Board
Once I have my Project,·that I mentioned in earlier posts,·finished I would like to take it and using the carrier board solder everything in for more durability. My Questions for this are:
1. are the holes in the board similar to the bread board, (How are they set up?)
2. I have two a/d Converter chips. Do I just stick the pins in the holes and solder, or is there another way to do that.
3. If my circuit fits on the board of education(Just barely) will it fit on this board. (Knowing how the holes are aranged would help0
4. Any other advice?
Thanks a million
Don
Thanks a million
Don
Post Edited (Masterchief1517) : 5/23/2007 1:35:23 AM GMT
The hole patterns for the "prototype area" are documented on the schematic --
http://www.parallax.com/dl/docs/prod/schem/supercarrierbd.pdf
The holes are on 0.1 inch centers though, same as most plastic breadboards like the one on the BoE, and the BS2 pins do appear to be brought out to SIP sockets on each side of the BS2 socket.
I didn't count the holes but the breadboard area on the BoE is pretty small, I doubt you would have any problem fitting your circuit onto the BS2 carrier board if you have it working on the BoE breadboard.
Definitely use sockets for any ICs you use.
Edit: I agree with PJ Allen that the Supercarrier board is probably a better choice. You get a decent 5 volt power supply built in (with a DC power jack) and the prototype area is documented and closely resembles the board on the BoE.
- Rick
Post Edited (RDL2004) : 5/23/2007 2:19:17 AM GMT
Learning to order from these sites takes a little bit of dinking around though.
-cjkogan111
If you order sockets from Digikey or Mouser, they also sell the items required to make PCB's. Radio Shack sells a kit for PCB's but I wouldn't recommends it.
Just a thought.
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
