upload java files
I can't upload java files in my post.
With-in the Attachment Manager I can the error "* You cannot upload files that use MIME type : text/java."
Can this be fix please
If you enclose your files in a ZIP archive you will be able to upload them. Take care.
File Attachment :
LinkMatik.java 1KB (application/octet-stream)
This file has been downloaded 1 time(s).
Many Thanks
Jonathan
-Jon
www.jonkeinath.com
I just tried to upload a compiled java file (*.class) and that gives the error you mention.
You must upload the source (*.java).
I suspect your windows setting is not to show filename extensions. There are
2 identical filenames, one with extension .class and one with extension .java
To enable viewing of extensions
From windows explorer menu extra->folder options
select tab view
uncheck "hide extension of known filetypes"
click ok
You should now be able to see the filename extensions.
regards peter
I am uploading the source (*.java) file if you look your file have a different MIME type of mine? Why is that? It is not just m to has this problem.
Jonathan
in internet options. My privacy settings are set to either minimal or standard.
regards peter
