boe-bot navigation using sonar to follow person
for a school project i am trying to use sonar to get a device such as the boe-bot to follow a person. We however want to use the boe-bot's capabilities to follow an object using the ping sonar sensors.· Is there any way that we can make this possible?· Please send us any information regarding this topic.· We would greatly appreciate it.
P.S. and if anyone has any code to do this please send it to us.· we aren't experienced and frankly don't know what we are doing totally so any extra help will be greatly appreciated.
- Stephen
Step 1: Go through the activities in Robotics with the Boe-Bot. Each one is just a few pages. You can kick out Chapter 6 if you want. The example code in Chapter 8, Activity #2 (you'll have to start in Chapter 7 and work through) will work for person following so long as the person is moving very slowly.
Step 2: There's also a posted application in the Stamps in Class "Mini Projects" thread that shows how to scan for, detect, and go to the closest object. All this can be done on the fly for person following provided you have carefully studied Robotics with the Boe-Bot.
Robotics with the Boe-Bot PDF:
http://www.parallax.com/dl/docs/books/edu/Roboticsv2_2.pdf
Stamps in Class Mini Projects:
http://forums.parallax.com/forums/default.aspx?f=6&m=98784
On the Stamps in Class "Mini Projects" page, there are two links with pictures, and a video clip of the Boe-Bot using the Ping))) ultrasonic sensor to scan for and go to the closest object. The links are in the Boe-Bot + Ping))) Ultrasonic Rangefinder section.
Now, a better way to do it might be to attach an infrared beacon to a person's ankle or shoe. That way, you can use the concepts in Robotics with the Boe-Bot chapter 7.· The detection range will probably be better too.
Andy Lindsay
Education Department
