Temperature measurement and logging
yurij
Hi - I am new to interfacing hardware to a PC, but I·need to·measure and record the temperature of 3 outdoor items every few seconds so I want to give building it a try as an introduction microcontrollers.·Which kit - or combination of kits - should i buy to build·this?·thx -yurij
86,400 / few (3?) = 28,800 times three we are back to 86,400 measurements per day.
Need to know:
How many days
How big of number for each item.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
The HomeWork board would be the simplest, but it's only available in packages of 10. RadioShack used to carry the HomeWork board as a single kit and you can sometimes still find them at a discount. Other than that, the Board of Education together with any 24-pin Stamp model would be fine. I would suggest the BS2pe (or BS2p or BS2px) since they have additional capabilities that you don't need now, but may find useful in other projects.
Also, download Stamp Plot Pro from www.selmaware.com which can record data from the Stamp board and would allow you to easily plot it and analyze it.
Just for the record, RadioShack is still selling the BASIC Stamp Activity Kit which includes a HomeWork Board and the What's A Microcontroller Parts & Text.· You can also order it directly from Parallax:
http://www.parallax.com/detail.asp?product_id=90005
Almost all of the Applied Sensors experiments will work fine on the HomeWork Board, with some care taken to the pump·power supply in the last chapters.· The temperature datalogging activities would be no problem.
-Stephanie Lindsay
Editor, Parallax Inc.
http://forums.parallax.com/forums/default.aspx?f=5&m=177978&p=1&ord=d
Yes, you'll need to buy a couple more DS1620 sensors (assuming we are talking about measuring air temperature). The temperatures cannot be measured simultaneously, but they'll only be a few milliseconds apart, which should be fine what you're doing.
Andy Lindsay
Education Department
I have· temperature· humity data logger and the way that it is setup is that it only log the changes
that way you do not have so many data points you only have changes
My set point ..........5* F Data log change and i can change the set point any thing that i need it to be
I can also set how many seconds between data points........... every 10 seconds
This was done with Two Basic Stamps
Let say that you temp reading like·this
·10:00:30·· 75.5·················· ·start·· 75.5· The Logger Data that you would have and you could have a
·10:00:40·· 75.5··························· ·76.1·· Time Stamp for each line
·10:00:50·· 75.6················· ··End····75.4··· This way you would not use up as much memory this way
·10:01:00·· 75.7
·10:01:10·· 75.8
·10:01:20·· 75.8
·10:01:30·· 76.1
·10:01:40 · 75.7
·10:01:50· ·75.8
·10:02:00·· 75.9
·10:02:10·· 75.4
·I hope that you can under stand what i have put here and i hope that this help you in what you want to do
··Thanks for any··that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 5/23/2007 3:20:57 AM GMT
In high resolution mode the DS1620 can read out to better than 0.01 degree, and with individual calibration, it is stable enough to achieve accuracy of 0.1 degree.
It is kind of bulky though for measuring the temperature of a surface. Maybe it can be fastened to back (?) surface with a heat transfer adhesive.
Another option is a one-wire sensor like the DS18B20, which is available in a smaller TO92 package. Its performance is similar to the DS1620, but it uses a OW interface. For that you would need one of the "advanced" Stamps (BS2p, '2pe or '2px), which include the ability to read OW devices.
For measuring temperature differences, and especially for measuring temperature differences involving small objects and surfaces, thermocouples are king. They can be fabricated from very fine wire that easily equilibrates without disturbing the system under test. A pair of thermocouples can be hooked up back to back, so that their voltages cancel when they are at the same temperature. When they are at different temperatures the voltage is proportional to the temperature difference. You would use another sensor (like a DS1620) to measure the ambient temperature accurately, because thermocouples do not provide great absolute accuracy. Thermcouples produce a very low voltage, so they require a high gain amplifier and an analog to digital converter to read the temperature difference. Parallax sells an interface that would be suitable, but it uses the OW interface available only on the advanced stamps. Or you could go the route using a traditional ADC.
There are analog temperature sensors that are quite accurate or can be made so with individual calibration, for example, the AD592 or the LM34.
Tracy Allen
www.emesystems.com
