No. The whole idea of a reset is to override anything (like some kind of programming error) to force the Propeller into a known, "safe" state.
You could design some external hardware that would delay an external reset signal for a few milliseconds, yet present the same signal (undelayed) to an I/O pin where a cog could watch for it. This would not prevent a brown-out/power-failure type of reset nor would it prevent a software initiated reset (REBOOT statement).
Thank Mr Mike Green . The idea is good. My problem with reset is that.in my project propeller counts sensors data
and write the values to eeprom with basic i2c object also when a power failure the propeller run from a ulracapacitor
and save values to eeprom.but when the user close vbasic program the pc close serial port and then propeller goes
reset.in this case I cant write last values to eeprom.are there any way to make this : when pc close serial port propeller
dont reset itself
Check the schematic of the Propeller board you are using. You'll see that there's a connection between the reset pin and the serial port DTR signal. This is used by the Propeller Tool to reset the Propeller for downloading. You simply have to put a switch in that line so that it's connected when you want to download a new program to the Propeller and disconnected when you're running your application.
dont reset itself
