Motor with Taper RK25T
Hi all,
I am stuggling to put command to RK25T motor with taper to specific position.·
http://www3.alps.co.jp/WebObjects/catalog.woa/PDF/E/Potentiometer/MetalShaft/RK25T/RK25T.PDF
Have anyone ever worked with·taper before with BS2?·
If you are using the BS2, then you should re-post in the Basic Stamp Forum.
What are you using to drive the motor ? You'll probably need an h-bridge.
What are you using to read the pot ?
Bean.
“The United States is a nation of laws -· poorly written and randomly enforced.” - Frank Zappa
www.hittconsulting.com
