Normally Closed Relay
I have a 12 volt circuit that I would like to temporarily turn off with a Stamp pin while the Stamp does other things, then turn the circuit back on.· The 12V circuit could have a wide range of loads and the current could be anywhere from 200mA to 10 amps.· I am assuming the best way to do this is with a relay switched·by a transistor.· Does anyone have a recommendation for a transistor/NC relay combination for this application?
Do you possibly have a spec for a relay that would fit my needs?· Preferably solid state.· I've been on the Crydom web site, but I really don't know how to spec out a relay.
Chris I.
What would you do differently for an SSR?· I found one at Crydom that will fit my needs initially (it only switches 5 amps).· The part number is DC60S5-B.··· What I am using it for is to temporarily turn off a string of LEDs.
Chris I.
If you are only switching 10 amps at 12VDC then a fet should be all you need and you can drive it directly from the stamp pin.
Since you are driving LED's I assume the current is only one direction. A relay allows you to go both directions while an SSR typically switches AC voltage at the zero crossing point.
I would think you would want to regulate the current though, sounds like a lot of LED's to take 10amps unless it's 5 red/orange luxeon3's with a big heat sink.
Here is a to220 package that takes 15 amps up to 60V. .86 cents qty 1
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=381989&Row=863498&Site=US
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Post Edited (metron9) : 6/9/2007 3:53:14 AM GMT
You may want to check out this thread:
http://forums.parallax.com/showthread.php?p=654078
Also, I have a question about the operation.· If I want to run current through the MOSFET, should I pull the gate high with a 10K resistor?· How then would I switch it down?· Through a transistor?· Will I need a heatsink on the MOSFET?
BTW, Yes, I'm running·a lot of·LEDs on this system.
Chris I.
In the specs, you will see data related to Vgs ( Voltage, gate with respect to Source) and corresponding values of Rdson ( resistance, Drain to Source in the ON condition). You want Rdson to be a fraction of an ohm when voltage signal on the gate is 5 volts. Some specs show this as a graph.
The IRL510, IRL 520 mentioned previously are specifically designed for microprocessor signal levels and will conduct fully with 5 volts on the gate.
Tom Sisk
http://www.siskconsult.com
Crydom run a nice range of 'DC Load' SSR's in the CMX range...mosfet switching stage...
www.crydom.com/products/productFamily.aspx?id=21
I have attached the Datasheet also ...
Quattro
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 6/13/2007 3:05:36 AM GMT
Question, Why would someone select a part that is 10 to 20 times higher price given it can perform the same task or is it different than a fet in it's operation or meets some other criteria for safety or something else?
They're called high side switches.
Google search for "Infineon Profet" if you're interested. Incredibly low on resistances for the high-power parts.
Downside? Trying to find a distributor that sells a single quantity of the exact part you need.
Of course, for a hobbyist, just use a relay!
As for using a DC or AC SSR versus a fet, it's all about packaging. An SSR is a conveniently packaged fet. Easier to drop in and replace if it blows up.
