Encoder wiring - how to test and hook up.
I have an encoder,· series TRD-S/BD.· I'm trying to manually test it with a volt meter.
The specs are:
Operating voltage:·· 10.8-26.4vdc· (I'm using 24 volts)
signal format:········ ·Quadrature output
Output config:········ N channel mos FET.· Open drain output
Output voltage:······ "H"·
··························· "L"· 0.4 V or less
Wiring:
· Blue:····· 0 v
· Brown:·· Power Supply (24 volts for me)
· Black:····OUT A (100 pulses per rotation)
· White:·· OUT B (100 pulses per rotation)
· Orange: OUT Z (1 pulse per rotation)
Link: http://web5.automationdirect.com/static/specs/encoderld.pdf
The output wave form I was expecting was to be between 0 and 24 volts, but the "H" value of "
" in the specs has me a little confused.· Can anyone advise me how I can test this out, and if you know, how I can hook this thing up to my stamp?· BTW, I'm using the Stamp PLC so 24 volt inputs are okay.
When I hook things up and measure, I don't get any appreciable measurement on the volt meter.· Do I need to apply a load?
Thanks.
Jeff
Post Edited (jeffjohnvol) : 5/19/2007 7:56:50 PM GMT
The specs are:
Wiring:
· Blue:····· 0 v
Thanks.
Jeff
Thanks!
