broadcast mode for spinning beginners....
Hi, since i got the prop i have fun playing with it.
Now i try to find out to send the the tV signal over broadcast so i dont have to unplug the propboard and run to my tv every time to look at changes.
What do i have to change to do that.
I have read that you have to change the mode to 0100 but where, and 55_000_000 or 55_250_000 and where to change that
i have the first 4 pins p0..p3 for the tv hocked up.
How do i do it ?
Anubis Bot
How do i do it ?
Anubis Bot
![jumpin.gif](http://forums.parallax.com/images/smilies/jumpin.gif)
Parallax Forums - If you're ready to learn, we're ready to help.
And i only get a black picture with some blue and green flickery on the tv.
Do i nned some extra hardware like a antenna ?
Anubisbot
because i got a 5 mhz crystal, but in the Crystals PDF it says only good for 3,567 to 70 MHz
Does this means that i only get my prop running at 70 MHZ and would that kill my tv Broadcasting.
Funny part is that when i hoock it up to the tv in baseband it works fine.
Anubisbot
5mhz is the recommended frequency for the crystal, used with 16xpll it gives you 80Mhz
If you use BW-only, you'll also get a cleaner display.
