problem with hydra cd/ Removing Read-Only**HELP!!
When trying to access the executable program bmp2spin we are unable to take the read-only feature off. This causes us to be unable to run this program and take advantage of its features. We already tried copying the files off the CD and still had no success. Without the function of this program we are unable to take full advantage of the Hydra gaming system. Any help you can provide would be appreciated. The attached file contains a Print Screen of our problem. Thank You.
bmp
513K
Here are a few interesting kb articles I found:
http://support.microsoft.com/kb/326549/en-us
http://support.microsoft.com/kb/256614/en-us
http://support.microsoft.com/kb/323002/en-us
Those are the properties of the folder. If you've done what I said, the actual files within it should be read/write.
