Bluetooth & X-Bee Distance Considerations
Folks -
Would any of you fine·people who have had experience with Bluetooth and/or X-Bee care to comment on the distances one can expect from such systems?
Do general RF considerations apply as far as interference, and best transmission practices, or are there any special or unique considerations?
Are multiple channels available with either system?
The planned application needs a bi-directional (half duplex) wireless connection, and I'm trying to avoid the cost of cellular if I possibly can. It may or may not require multiple channels.
Thanks in advance.
Bruce Bates
Post Edited (Bruce Bates) : 5/16/2007 8:18:37 PM GMT
Thanks in advance.
Bruce Bates
I'm a little frustrated with bluetooth. it's a little buggy still. If I use my usb adapter on another computer or switch from my 10m to 100m I basically have to reinstall the whole setup to get it to work. that being said, it was pretty cool to setup a peer to peer network over bluetooth it took all of 2 minutes to configure and have it up and running. Bluetooth looks very promising but I feel it needs a few wrinkles worked out.
A complex design is the sign of an inferior designer. - Jamie Hyneman
I use a Mac and a Palm with built-in Bluetooth for some things and have never had problems. This is with two Bluetooth keyboards and two Bluetooth mice, two Macs, the Palm, a printer with a Bluetooth adapter, and occasional use of a Bluetooth dialup modem.
Correct me if I'm wrong, but you mentioned that, "Bluetooth is ... intended to replace wired low speed serial peripherals."
But, isn't the Bluetooth a replacement for high speed serial peripherals. Zigbee, on the other hand·is used for low speed data rates.
E=mc^2
When Bluetooth was proposed, it was to replace multiple conventional low to medium speed serial channels typical of mice, keyboards, modem links, and compressed or moderate fidelity audio. Data rates were expected to be in the 20-50 kiloBaud range or lower, occasionally higher. Range was to be fairly short, typical for the "rat's nest" of wiring associated with a desktop computer, perhaps 10 meters. Later the extended distance / higher power Bluetooth standard was added allowing for up to 30 meters' range.
ZigBee was an attempt to combine both worlds by using an Ethernet-like protocol with addressible packets, yet using a moderate data rate to keep power consumption low, yet allowing for an intermediate range (between Bluetooth and WiFi) when enough power was available. The data rate is about 250 kiloBaud.
The WikiPedia has some good articles on the three standards and their histories.
Post Edited (Mike Green) : 5/22/2007 3:30:22 PM GMT
