Boe Bot problem
Ive been having a problem with the Boe Bot. When I program it to go straight in the GUI Bot program, it does 360's instead, and when I program it to do 360, it goes straight, and I canot figure out how to make it do simple turns. Any help would be appreciated.
Do you have the leads reversed on one (ONLY one) of the wheel servos?
Bruce Bates
If you program both servo's to go in the "same direction', since the servos are mounted back to back, the BOE-Bot will spin in a circle. So you'll have to program one servo PULSOUT 4, 850, and the other servo PULSOUT 5, 650, in order to make the BOE-Bot go forward.
