Propeller Tool mods
![Baggers](https://forums.parallax.com/uploads/userpics/316/nM38GQVOEYVFZ.gif)
Hi All, ( especially the good people of Parallax )
I'm probably not the only person to want this, but...
Is there any chance of you modifying the propeller tool, to allow downloading·binary files to eeprom addresses >32KB
Or downloading binaries that are bigger than 32KB so that we can download apps in ONE file?
Or give info on how to send data to the port, to make a quick downloader app ourselves, ie to download data to ram + run it. so I can knock up a quick VB app to do so, and release on the forum for others to use.
Thanks in advance,
Baggers.
Thanks in advance,
Baggers.
Paul Baker
Cheers anyway.
It's shame it couldn't be accessed in one send, oh well, no worries [noparse]:)[/noparse] thanks anyway, and for the prompt reply, yet again Parallax proving it's way ahead of the competition,
as I know for a fact that ( not sure if I can put there name on here ) but when I was using another company's chips they're response team always took well over a day to reply.
But Parallax gets full marks [noparse]:)[/noparse] 4 minutes! wow, I'm very very impressed.
Keep up the great work, that makes your chips and forums the best!
Baggers.
Consider adding an SD card to your system. It only takes 4 I/O pins and some memory for the routines needed. You can load programs directly off the SD card as well as read (and write) data. Have a look at FemtoBasic for an example of this. You could in fact use FemtoBasic to copy programs and/or data from the SD card to the boot EEPROM or EEPROM locations above 32K.
It's for my ManicMiner clone + others that I plan to do.
Cheers for the extra options anyway Mike, yet again you come to the rescue with other options I mightn't have thought of.
and another reason why this forum is the best on the net [noparse]:)[/noparse]
