Why won't editor software recognize Stamp? different problem.
I'm sure somewhere on this form this is talked about but in my searches I can't find anything.
I'm using my stamp last night and all is well I uploaded a program. and then made a few changes and tried again and it won't recognize my stamp.
the stamp editor says NO on loop back and echo. I double checked to make sure that I didn't unplug the cable at either end. and still nothing. I thought it was a glitch with my com port so I rebooted my PC and still the same issue. I know it's not the stamp. the program that I have on the stamp sends debug messages so I know the stamp is doing that part of it. I thought that maybe it was the carrier board, and tried to connect a how brew stamp and the problem is the same. My current though is that my cable is bad. but it's wierd that it went bad so suddenly. I don't even think I touched it when the problem started happening.
BS2sx
Serial cable
latest editor.
thanks for your help
A complex design is the sign of an inferior designer. - Jamie Hyneman
BS2sx
Serial cable
latest editor.
Check the battery or power supply first.
Bruce Bates
It could be the DB9 socket on the Stamp board. You could check the solder connections there.
If the Stamp can successfully send messages to the PC, then it's either the loopback connection (between pins 6 and 7) or the input to the Stamp from the PC isn't getting through.
Thanks for your help and time I'll let you know.
Straight through DB9 serial cable.
Post Edited (Dgswaner) : 5/16/2007 2:45:38 PM GMT
I took·my Boe-Bot apart to install the Gripper kit and when I put it back together the editor didn't recognize the Basic Stamp. The problem·was the same whether I used the USB converter or a direct connection to the serial port.·In both cases when I tried to identify the port or run a program, the Loopback and Echo both read Yes for the COM port I was·using, but I got the "No BASIC Stamps found" message when I tried to run a program.
Any ideas on what I need to do to remedy this situation?
Bot Learner
I had one of the batteries in backwards.
Thanks for the help Mike!!
Bot Learner
thanks for all the help.
The only option I have left I think is to try a different usb cable or power.· I have a power supply that is 9v 600mA.· I see that a 9v 300mA P/S is recommended for the stamp.. Can I use the 9v 600mA p/s to try and see if that will show up in the Device Type when i click the Identity button?· Also, i use the serial ports on the computers for other things, so i know they are enabled and working in the bios.· The BOE board is switched to position SW0.
Any Idea's???
The power switch has 3 positions. The first position is OFF. The second and third positions provide power to the Stamp. The third position also provides power to the "servo" connectors which can also be used for some sensors.
Maybe that helps at all?
Blake
