Microsoft Robotic Studios and BOEBOT not working, need help, please
Hello
I am a teacher in a technical high school. My student bought the MRS BOEBOT Kit. We followed the instructions to the T ("BT Boebot Robot controlled by MRS" #28118?). We have not been abel to get it too work. We tried 3 different computers and 2 different BT adapters. At the dashboard part of the instruction all we get is the the wheels turning in opposite directions. Has anybody got this to work at all. We are able to connect to the EB500 because the LED is on but we are not able to control the wheels at all. Thanks in advance
Did you center both servos per the instructions in Robotics with the Boe-Bot v2.2, Chapter 2, Activity #4?
Are you using v1.4 of the instructions PDF?
Are you using Microsoft Robotics Studio (1.0)?
Andy Lindsay
Education Department
A few days ago however, I updated to version 1.5 CTP of MSRS. I have tried many times to get the first tutorial to work, but with no response. The Boe-Bot does indeed acknowledge a connection with the computer and I get the two beeps and the led on P15 along with the green led on the eb500 light up properly. The wheels on the robot begin to slighly vibrate indicating that they are receiving pulses from the Basic Stamp. The problem arises when I try to use the Simple Dashboard service to move the Boe-Bot. After entering the parameters 'localhost' & '50001', connecting and double clicking the /drivedifferentialtwowheel service I press drive and try to control the Boe-Bot with the cursor and nothing happens. It appears as if the service does not link up properly. I have double checked the ports and the _autonmode settings to be right. I would like to add that the second tutorial, the one in which the Boe-Bot roams semiautonomously does work completely well and does a fantastic job at it too. I have done my best to try to rule out any possible mistakes that I could have commited and think that there might be a problem with version 1.5 of MSRS.
I strongly recommend Mr. eccmaster to try the Semiautonomous Navigation Test even if the remote control Boe-Bot does not work to see if the Boe-Bot is responding and completing message cicles with the computer. Also,··it never hurts to have fresh alcaline batteries·because apparently some messages are garbled if the eb500 module doesn´t have a good power source. I´ll finish saying that this kit in conjunction with MSRS is an excellent platform and that it´s really great that Parallax made this agreement with Microsoft. Hopefully these problems are some things that we are missing and will soon be fixed.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 5/17/2007 1:38:16 AM GMT
