Oh! PING also...
Is there a 'Roaming w/ PING' Doc. out there that doesn't assume that you have the mounting bracket? cause if there is, I couldn't find it. Thx again.
MIKE
MIKE
Are you talking about the "roaming with ping" bs2 program ? Have you looked here, http://www.parallax.com/dl/docs/prod/audiovis/Distance28015.pdf
You can also use the roaming with ping program and just modify it and extract the servo commands.
Rob7
