adding a second stop bit to serout? — Parallax Forums
SteelSteel Posts: 313
edited 2007-05-14 19:12 in General Discussion
Could anybody help me add a second stop bit to the serout function? Can it be done in·sxb, or does it need to be done in Assembly?
I can't find anything in the SEROUT in·the help file.
Thanks.
Shaun·
  • JonnyMacJonnyMac Posts: 9,799
    edited 2007-05-14 18:43
    The standard SEROUT uses 8N1; that said, an additional stop bit can be added after your SEROUT by using PAUSEUS for the required bit time. Here's a way to encapsulate SEROUT into a subroutine (which saves code space) and specify the number of stop bits (0 or 1 input will still give one stop bit):
    SUB TX_BYTE
      tmpB1 = __PARAM1
      IF __PARAMCNT = 2 THEN
        tmpB2 = __PARAM2
        IF tmpB2 > 0 THEN
          DEC tmpB2
        ENDIF
      ELSE
        tmpB2 = 0
      ENDIF
      SEROUT TX, Baud, tmpB1
      DO WHILE tmpB2 > 0
        PAUSEUS BitTime
        DEC tmpB2
      LOOP
      ENDSUB
    Of course, you'll need a PIN definition for TX, and CONstant definitions for Baud and BitTime. Use this declaration:
    TX_BYTE        SUB    1, 2
    You may want to use the MAX operator to limit the maximum number of additional stop bits.
    Post Edited (JonnyMac) : 5/14/2007 7:33:13 PM GMT
  • SteelSteel Posts: 313
    Thanks jonnymac.· I was going to do Pauseus, but I guess I just needed to make sure I wasn't missing anything.
    Thanks for the help!
    Shaun
