Timing and Jitter — Parallax Forums
Timing and Jitter
Andy McLeodAndy McLeod Posts: 40
edited 2007-05-16 16:02 in BASIC Stamp
I am trying to send FREQOUT commands from a pin on the BS2px triggered by a PPS from a Garmin GPS module. The Garmin puts out a usable PPS pulse at a very stable 1hz. What I would like to do is output the PWM signal generated by FREQOUT at the exact interval (plus instruction time) of the PPS signal. Using the POLLMODE, POLLRUN commands I can get a behaviour similar to this, but with about a 300usec jitter. Is there a way to lock the FREQOUT execution to the interval of the PPS?
Anyone ...?
  • stamptrolstamptrol Posts: 1,731
    edited 2007-05-14 16:48
    I've never tried that particular exercise, but intuitively, there are two parts to analyzing the problem.
    1. once the FREQOUT is triggered, is its width consistent, or is the jitter in the output pulse width?
    2. or, is the variation in the leading edge-to-leading edge time of each PWM pulse?
    I would guess the pwm pulse width should be fairly stable.
    But, if the stamp is not ready to go at the instant the PPS is detected, there will be some variation if the stamp is off doing something else and gets back to the PPS service routine while the PPS is in the middle of its pulse.
    Can you show us your code?
    Cheers,
    Tom Sisk
    http://www.siskconsult.com
    edited 2007-05-14 16:51
    If you want the tightest possible timing, use a construct with POLLWAIT like this on the BS2P:
    POLLIN gpsppspin,ppstarget
    POLLWAIT 8
    FREQOUT .....
    The POLLWAIT 8 keeps the Stamp awake in an event pending state, sort of like the Propeller WAITPEQ command. When the pin changes state, the execution falls through to the next command immediately, within microseconds. However, there will still be a deterministic delay of 100 microseconds or so for the interpreter to work on the FREQOUT. But it is deterministic, not jittery. Other values from 0 to 7 after POLLWAIT induce a power saving sleep cycle, but POLLWAIT 8 keeps the Stamp alert for shortest possible latency.
    I expect the jitter came from having a loop waiting to execute the POLLRUN--There is an unprediictable element in where the PPS falls in the loop. The BS2p won't be doing anything else while it is in the POLLWAIT state.
    Tracy Allen
    www.emesystems.com
    edited 2007-05-14 16:56
    The jitter is due to the fact that the Stamp interpreter is single threaded (does only one thing at a time). Even the POLLxxx stuff is only done in between interpretive instructions which can vary in execution time depending on the specific instruction involved. Since the GPS is not synchronized with the Stamp interpreter, the PPS pulse can be present for some time before the Stamp notices it at the end of the current interpretive instruction.
  • Andy McLeodAndy McLeod Posts: 40
    edited 2007-05-15 14:08
    Here is some code as requested:
    PING1.bpx
    ' {$STAMP BS2px, ping2.bpx}
    ' {$PBASIC 2.5}
    Setup:
    POLLIN 7,1
    POLLRUN 1
    POLLMODE 3
    Main:
    'INPUT 7
    ' VERSION 1: (result ~100microsecond jitter)
    'HOLD: IF IN7 = 0 THEN HOLD
    ' FREQOUT(pin,duration,freq)
    ' duration in units of .166 microseconds
    ' freq in units of 6.02 Hz.
    'FREQOUT 0, 6, 5000
    'GOSUB HOLD
    ' VERSION 2:
    GOTO Main
    END
    PING2.bpx
    ' {$STAMP BS2px}
    ' {$PBASIC 2.5}
    Setup:
    Main:
    FREQOUT 0, 6, 5000
    RUN(0)
    END
    This setup gives me about ~120msec of jitter from leading edge to leading edge - which is merely borderline OK.
    I'm not sure I understand Tracy's construct. the POLLIN command uses the structure POLLIN pin,state - not a input pin, output pin as it seems to be suggesting. What am I misreading here?
    edited 2007-05-15 15:43
    Hi Andy,
    I meant to imply input pin, target state. With the pins assigned in your listing, it would be,
    DO
      POLLIN 7,1   ' <---- pin,targetstate, looking for 1 on pin 7.
      POLLMODE 2      ' need this to activate polling
      POLLWAIT 8    ' program holds here awake in an ASM loop for target state
      FREQOUT 0,6,5000
      '  anything else?
      POLLIN 7,0  ' looking for 0 on pin 7, to sync loop to pps
      POLLWAIT 8   ' waiting for pin 7 to be 0
    LOOP
    Tracy Allen
    www.emesystems.com
    edited 2007-05-15 17:05
    Bingo! I lost the fact that we had to go to a new state at the end of the loop. Thank you Tracy.
    edited 2007-05-15 18:37
    By the way, the POLLMODE command does not have to be inside the loop.
    I took a look at the timing. The Stamp manual hedges, saying the "response time with duration set to 8" is "less than 160 microseconds" for the 2p or "less than 250 microseconds" for the 2pe, and it doesn't say anything explicitly about jitter.
    With a 'scope set to trigger on an input edge to the POLLIN pin, ans with a HIGH 14 following the POLLWAIT 8, I am seeing a latency of 200 microseconds with a jitter of 10 microseconds before the edge of the HIGH 14. The interpreter latency for a HIGH 14 by itself came out as 60 microseconds, with no jitter to speak of, so that leaves the latency for the POLLWAIT at 140 microseconds with a jitter of 10 microseconds. I was testing thatI on a beta version 1.6 of the BS2p, which is a little different from earlier versions. Note that it also depends to a small amount on which pin you use. For example pins 0, 1, 2, 4, and 8 are about 5 microseconds faster than the other pins, because of the efficient way the tokenizer stores powers of 2. Anyway, the latency for the BS2p is a little better than the value stated in the manual.
    I also ran the test on a BS2pe. There it came out with a latency of 380 to 405 microseconds, minus 110 microseconds to interpret the HIGH command, leaves 270 to 295 microseconds for the POLLWAIT 8 latency, with a jitter of 15 microseconds. That is longer than the value stated in the manual, which is "less than 250 microseconds". That may be due to the way I set that up on auxio. I use POLLWAIT a lot with the 'pe, but in the modes that put the Stamp to napping.
    Tracy Allen
    www.emesystems.com
    Here is our working code for this project. This monitors a Garmin GPS17-HVS for RMC string and the PPS pulse, then sends out a stepped ramp using FREQOUT to a transducer. The time and position are recorded to the stamp EEPROM.
    ' {$STAMP BS2px}
    ' {$PBASIC 2.5}
    ' RUNTIME VALUES
    CW CON 1
    CHIRP CON 2
    ' CONSTANTS:
    MEM_SLOT_MAX CON 7
    MEM_POS_MAX CON 2047
    SERIAL_TIMEOUT CON 2000 ' Units of .2ms
    LOG CON 1
    READDATA CON 1
    BAUD4800 CON 813 ' 8N1
    BAUD19200 CON 188 ' 8N1
    ' VARIABLES: (max 26 bytes)
    LATDEG VAR Byte
    LATMIN VAR Byte
    LATDEC VAR Byte(5)
    LONDEG VAR Byte
    LONMIN VAR Byte
    LONDEC VAR Byte(5)
    HR VAR Byte
    MN VAR Byte
    SEC VAR Byte
    POSVALID VAR Byte(2)
    TMP VAR Byte
    idx VAR Word
    slot VAR Nib
    Main:
    'Initialize slot and write postion index.
    'slot should never be less than 1 or the
    'program itself will be overwritten!
    slot = 1
    idx = 0
    DO
    FREQOUT 0,3,4146
    FREQOUT 0,3,4312
    FREQOUT 0,3,4478
    FREQOUT 0,3,4643
    FREQOUT 0,3,4809
    FREQOUT 0,3,4975
    FREQOUT 0,3,5141
    ' anything else?
    'Baudemode calculation X = INT(4,000,000 - Baudrate) - 20
    SERIN 1,BAUD19200,SERIAL_TIMEOUT,MOVEON,[noparse][[/noparse]WAIT("$GPRMC"),SKIP 1,DEC2 HR,DEC2 MN, DEC2 SEC,TMP,STR POSVALID\1,DEC2 LATDEG,DEC2 LATMIN,TMP, STR LATDEC\4,TMP,DEC3 LONDEG,DEC2 LONMIN, TMP,STR LONDEC\4]
    MOVEON:
    'LATDEC=0101
    'LATDEC=LATDEC*10000
    DEBUG "GOT HERE", CR
    'DEBUG STR TEST, CR
    DEBUG "TIME HR: ", DEC HR, "MIN: ", DEC MN, "SEC: ", DEC SEC, CR
    DEBUG "VALID POS: ", STR POSVALID, CR
    DEBUG "LAT:", DEC LATDEG," ",DEC LATMIN, "." , STR LATDEC, CR
    DEBUG "LON:", DEC LONDEG," ",DEC LONMIN, "." , STR LONDEC, CR
    ' Protect ourself from over-writes
    'DEBUG "SLOT: ", DEC slot, " IDX: ", DEC idx, CR
    ' IF (slot < 1) OR (slot > 7) THEN Main:
    STORE slot
    ' IF idx < (2047 - 26) THEN NEXTSLOT
    ' write the data
    IF LOG THEN GOSUB WRITETIME
    idx = idx + 6
    IF LOG THEN GOSUB WRITEPOS
    idx = idx + 8
    HR = 00
    MN = 00
    SEC = 00
    LATDEG = 00
    LATMIN = 00
    LATDEC = 0000
    LONDEG = 00
    LONMIN = 00
    LONDEC = 0000
    idx = idx - 14
    IF READDATA THEN GOSUB READTIME
    idx = idx + 6
    IF READDATA THEN GOSUB READPOS
    idx = idx + 14
    'idx = idx + 1
    LOOP
    END
    NEXTSLOT:
    slot = slot + 1
    idx = 0
    RETURN
    WRITETIME:
    WRITE idx,HR(0),HR(1),MN(0),MN(1), SEC(0),SEC(1)
    DEBUG "Wrote TIME...", CR
    RETURN
    WRITEPOS:
    WRITE idx, LATDEG(0),LATDEG(1), LATMIN(0),LATMIN(1), LATDEC(0),LATDEC(1),LATDEC(2),LATDEC(3)
    DEBUG "Wrote Position..", CR
    RETURN
    READTIME:
    READ idx, HR(0), HR(1), MN(0),MN(1), SEC(0),SEC(1)
    DEBUG "READ TIME HR: ", DEC HR, " MIN: ", DEC MN, " SEC: ", DEC SEC, CR
    RETURN
    READPOS:
    READ idx, LATDEG(0),LATDEG(1), LATMIN(0),LATMIN(1), LATDEC(0),LATDEC(1),LATDEC(2),LATDEC(3)
    DEBUG "READ POS, LAT: ", LATDEG, " ", LATMIN, ".",STR LATDEC, CR
    RETURN
